Question about Frigidaire Affinity ATF7000E Front Load Washer
DIY info for afinity series
Where can I find diagrams, etc. so I can effect some repairs on my own?
  • Anonymous Mar 09, 2008
    cant shut door
    President:
  • Frigidaire Master
  • 2,651 Answers
Remove main top( a few screws behind the unit. after removing cover there should be an envelope with the tech sheets either right ther on top of dispensor or downalog left side wall.(unless youve already had service and it s benn taken out and not returned
Posted on Feb 24, 2008
Looking for a wiring diagram for this tractor.
wiring diagram for this tractor Louie, Re POST year, make, model,#, etc. and complete question so we at fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 31, 2016 | Electrical Supplies
Wiring diagram
Wiring diagram Barbara, RE POST year, make model, # , etc and your complete question, so we at Fixya can answer your question effectively.
Mar 24, 2016 | Music
97 bmw nueteral safety switch wiring diagram
Go to www.autozone.com set up a free account then log in go to repair help then scroll down to wiring diograms
Jan 20, 2016 | 1997 BMW 5 Series
Vacuum routing diagrams
Go to autozone .com and sign up for free. You will then have access to repair manuals, parts prices etc. repair manuals with pictures, step by step repair info etc.
Apr 06, 2014 | 2005 Dodge Neon
Circuit diagram of zoom g1x
G1X circuit diagram is the same as the G1. They differ only on the pedal circuits.
circuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-0.jpgcircuit-diagram-zoom-g1x-shyexoo0xcste5eq310zs3ot-4-1.jpg
Give your email,and I'll send the circuit diagram.
Jun 24, 2012 | Zoom G1x Guitar Multi Effects Pedal with...
I have a problem with my 1995 Lincoln Towncar Executive Series. All the interior lights including the instrument panel buttons (all the buttons that usually light up when you turn the parking or headlights...
As far as the lighting problem goes ,looking at a wiring diagram I see they are controlled by a electronic control module .(LCM) - lighting control module . Checking power and grounds for the module and inputs from the main light switch would be a good place to start . Looking at a wiring diagram so you know which wires to test . Here is a web site for free wiring diagrams http://www.bbbind.com/free_tsb.html Enter vehicle info. Year , make , model and engine size. Under system click on lighting ,then under subsystem click on insturment panel lamps. Click the search button then the blue link.
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to Use Multimeter to Troubleshoot Common Problems
Electric Testing Techniques You Need to Know
Now looking at a wiring diagram for the power windows I see the LCM energizes the window regulator safety relay which powers the power windows , plus I see a left front door module . You may want to have a qualified repair shop with the right diagnostic tool to check for DTC'S - diagnostic trouble codes stored in the modules i mention . Probably save time and money . This may seam very complex but probably is somthing very simple ,a bad ground , corrosion , loose connection etc.... Knowing how to test electrical circuits is very important . Another problem is knowing where this componets are located in the vehicle . Buying a subscription to alldata would help . OE Info for Student and DIY er
Aug 12, 2017 | 1995 Lincoln Town Car
LED illuminates, no sound or picture. Relays will pop normally when power is disconnected and power switch is depressed, however unit is still inop.
O woe!
I would suspect the power board here, but it may not be the lone culprit as there are 3 boards involved in this set.
You may find that a series of capacitors have failed on one of the video boards. Now its not a case of replace the board as board swapping does not work to your advantage because of a possible domino effect. . Manufacturer recommends all 3 boards to be replaced simultaneously and not just to sell mor e parts....This is not a DIY in real terms unless you have a circuit diagram have the right tools to measure voltage output ( which is dangerous to say the least in a HT environment unless you are skilled) Thyere is also a degree of X radiation to think about.
The convergence will need to be retuned and this requires the ability to generate a hatch pattern on the screen with a sig gen and retune and align the convergence from inside the set. Many on here have ploayed board swap jockeys and eneded up paying more for the repair than calling professional help. Cheaper to take it to a repairer than a callout and cheaper than trying to save a $ by DIY.
If its still under warranty.. makie a claim as the repairs wilp be about $500
Please rate my help++++Thanks for using FIXYA
Nov 28, 2009 | Sanyo DP42746 42 in. Plasma Television
Underdash wiring ripped out by dog chasing a mouse
use the wire to strangle the dog and get a pro to rewire the dash it is not a diy job
Apr 03, 2009 | 1996 Chevrolet C/K 3500
Frigidaire Affinity ATF7000E Front Load Washer Logo
89 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
