Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
How to reset WD My Book World Edition to factory defaults?
I press the reset button but i couldn't reset it to factory defaults. What should i do? How many seconds should i press it?
Thanks.
  • 1 more comment
  • ysfozy Sep 14, 2008
    Thank you.
  • djon60 Oct 13, 2008
    i am having the same problems with resetting the drive. does manually formatting it erase firmware too?
  • Anonymous Mar 13, 2009
    all this does is resets the user name and password for admin login -
    i bought one second hand from ebay i want to do a complete wipe down and reformat any help?
Unplug power. Hold reset button. Plug in power while holding reset. Wait until light flashes, then release reset button.
Posted on Sep 14, 2008
  • O-tje Jan 04, 2011
    When I do this, is my data lost?
    Sniper:
  • 67 Answers
I don't think you can reset your hard drive.
when you plug it to your computer, it will show up as a icon in "my computer", right click on it and select "format". you will loose everything you ever had on it and it will be wiped clean.
Posted on Feb 23, 2008
  • Andrew Timleck Sep 10, 2010
    not even close. first you can't just erase all of the mybook this way. second of all you can factory reset the unit though this DOES ERASE EVERYTHING on it.
SOURCE:
How do I fix
Reset to Factory Settings
  • 1 Download the computer software for your Western Digital My Book World Edition if you don't have it installed on your computer. The software can be downloaded on the Western Digital website (see Resources.) Install the software to your computer.
  • 2 Go to the "Start" menu. Click "All Programs," the "Western Digital" folder and then "My Book World Edition Software" to launch the software.
  • 3 Switch to the "System" tab. Click either the "Restore Configuration" or "Full Restore" button on the tab, depending on your My Book World Edition drive.
  • 4 Click the "Browse" button, select the factory settings default restoration point, and then "General Restore" to return the unit to factory settings, or click "Full Restore" and then "Restore Factory Default," again depending on your specific My Book World Edition device. The unit powers off, all data is erased from the hard drive and the My Book is returned to factory settings.
Jan 14, 2015 | Western Digital 1TB My BOOK ELITE USB...
Reset wd my passport
If this is western digital world edition
The software can be downloaded on the Western Digital website.
http://support.wdc.com/product/download.asp?groupid=118&lang=en
Hope this helps
Nov 04, 2012 | Computers & Internet
Mionet problem
Your account has something called "account bug"
You will need to reinstall MioNet on all computers, reset the My Book World, then attach it to your new MioNet account. You'll need to download the Blue-Ring My Book World version of MioNet here:
http://www.MioNet.com/mbvista
Then, to attach your My Book World to the new MioNet account (just select a new username when you re-install MioNet), follow these directions:
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
You should now be able to sign in to the Shared Storage Manager as admin/123456.
5. Please open your web browsers and enter (without the quotes) "http://<IP address of My Book World>" or "http://mybookworld" in the address bar. The Shared Storage Manager web page will appear.
6. Once you have accessed the Western Digital Shared Storage Manager please select "General Setup" then choose "WD Anywhere Access settings." Use the default username of "admin" and default password of "123456" (without the quotes). On the following page you will have three buttons to select, please click on the "Reset" button. This will return the MioNet software on My Book World to default settings.
7. From within the MioNet Client, go to File > Remove Computer. Locate the My Book World (WDStorage, MyBookWorld, or whatever you named it) and remove it.
8. If you do not see a new window from MioNet informing you that you have a storage device available, "Scan for Cameras and New Devices…" to detect the unit.
Jul 16, 2009 | Western Digital 500GB My Book World...
Cant connect my 1TB WD world edition to my linksys router
Your My Book World should not be formatted or you will lose all ability to access it through the Network -- it will simply become a hard-drive at that point. There is software installed on the hard-drives that communicate with your Router in order to obtain an IP and be available as a Network Drive. If the drive and the Router are communicating, you should see an IP in the DHCP list of your Router. It is possible that the My Book World is not setup for DHCP, so if it is placed in an alternate environment with incompatible static IPs, it won't be able to access the Internet or be available locally. You can try a hardware reset on the drive and see if it pops up in your Router's DHCP/Client list, at which point it should also appear locally and over MioNet (MioNet will need to register the device to an account before it will appear in MioNet, but it must detect the drive locally in order to attach).
Jul 02, 2009 | Western Digital 500GB My Book World...
Can't Access my WD World Book.
what system you use for your WD World Book
Jun 17, 2009 | Western Digital 500GB My Book World...
I can't access my drive through mionet. My son accidently unplugged the world book and I can't access it ever since. Should I reinstall the mionet. I can't remember if there were any installation CD that...
Once the My Book World has been plugged back in, it will request a new IP from the Router. If the drive was unplugged accidentally, the ethernet cable may have also been knocked loose: make sure all cables are attached to the Router and the My Book World.
If your drive is still not appearing properly in MioNet, you can do a Hardware and Software reset on the drive. It will not affect your data, and it will allow you to re-attach the drive to your MioNet account. You do not need to reinstall MioNet to do this.\
Jun 11, 2009 | Western Digital My Book World Edition 1TB...
Wd my book world 1tb will not power up
check usb interface. problem in usb terminal. try to press round button switch.
Jun 01, 2009 | Western Digital My Book World Edition 1TB...
Mionet problem
The issue you are experiencing is account bug. You must reinstall MioNet and create a new MioNet account, then attach the My Book World to the new account. You will then regain your MioNet access.
http://www.MioNet.com/mbvista -- this is the download installer for MioNet which works for blue-ring My Book Worlds. The White-Light My Book World requires different software.
To create a new MioNet account, please use the following instructions:
Part A. Reset MioNet/Anywhere Access
1. Please open your web browsers and enter (without the quotes) "http://<IP address of My Book World>" or "http://mybookworld" in the address bar. The Shared Storage Manager web page will appear. The username and password it requests will be the same as your MioNet username, and the original password used for MioNet (if you changed your password on our website, it does not update the My Book World).
2. Once you have accessed the Western Digital Shared Storage Manager please select "General Setup", then choose "WD Anywhere Access settings". On the following page you will have three buttons to select: please click on the "Stop" button, wait until WD Anywhere Access status goes to "Inactive", then click the "Reset" button. Once the WD Anywhere Access Status goes to "Not Registered," (on older firmware, it will go back to Active), the My Book World has been properly reset. This will return the MioNet software on the My Book World to default settings. It will not harm your stored files.
Part B. Uninstall and Reinstall MioNet (on a computer located on the same network as My Book World)
1. Uninstall MioNet from one of your computers.
2. Insert your Western Digital installation disk or download MioNet from http://www.mionet.com/mbvista and launch the MioNet installer.
NOTE: You must use the installation disk or the link above to create your new account. Certain functionality related to the My Book World is related to the installer you use to register a new MioNet account. Failure to use the proper installer may result in the need to repeat this process.
3. Register as a new user. You will need to specify a new username and E-Mail address.
4. During the installation, MioNet should detect the now reset My Book World. Please add it to your new account.
Part C. Uninstall and Reinstall MioNet on your other computers
1. Uninstall MioNet from your other computers.
2. Install MioNet using the Western Digital installation disk or downloaded from MioNet from http://www.mionet.com/mbvista and launch the MioNet installer.
3. Register as a current user with your new account's information.
Please let us know what your new account name is and we will follow-up with additional information. We will also send you instructions on how to reset that account's password.
Oct 08, 2008 | Western Digital My Book Essential Edition...
Reset password won't work
How to reset the username, password, and network settings of a WD My Book World Edition hard drive. trnsp.gif Answer The directions below detail how to reset the username and password (for the Shared Storage Manager utility), and network settings of a WD My Book World Edition hard drive by using the recovery button on the back of the unit.
  • The username will be changed to "admin"
  • The password will be changed to "123456"
  • The network settings will be changed to DHCP (obtain an IP address automatically).
    1. Please ensure that the WD My Book World Edition hard drive is turned off and all cables are disconnected from the unit.
    2. Insert a paperclip or narrow tipped pen into the recovery slot on the back of the unit. Press and hold down the recovery button.
    3. While continuing to hold down the recovery button, connect the power cable to the back of the unit.
    4. Hold the recovery button down for at least 40 seconds while the unit boots up and then release the button.
    5. The unit may take up to three minutes to boot up completely. It is only necessary to hold down the recovery button for the first 40 seconds of this boot up process.
    Note: Western Digital recommends rebooting the computer system after making any network setting changes to the WD My Book World Edition hard drive.
  • then from WD software select General Setup->WD Anywhere Access settings->Reset.
    Jan 11, 2008 | Western Digital 500GB My Book World...
    Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
    67,921 people viewed this question
    Top Western Digital Computers & Internet Experts
    Ekse
    Alun Cox
    Marvin
    Marvin
    Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
