Question about Radio Shack Pro-97 Handheld Scanner
Help me I am in Brazil and I acquired one pro-97, it was working well, derrepente the sound of the frequency doesn't come out, only the sound of the keyboard, I already restarted but I didn't get, what should do,thanks, .Fabio frsracing@uol.com.br
Prezado Fábio,
Vi num site, http://www.fixya.com/support/t409718-help_me que você possui um Scanner Radio Shack Pro 97. Tenho um desses tambem mas estou com uma enorme duvida: Quando entro com a frequencia de 154.410Mhz ele automaticamente muda para 154.4075Mhz. Sabe me dizer como se pode mudar o "step" para poder colocar essa frequencia? Faça um teste no seu e me diga se ocorre o mesmo. Se você souber como se muda o step ficaria agradecido em saber.
Atenciosamente,
Rosendo
PS8RSA
Posted on Mar 20, 2008
Can I manually input the same frequencies from my pro 97 to a pro 2051 and receive the same audio as my 97? I know it would be time consumming, but can I do it? Thanks!
If I understand your question correctly, the answer is yes. The PRO-97 and 2051 cover the same frequencies and the same trunking systems, so you can program the same information into both. There is, however, no cloning capability between the two, so all programming will have to be done manually. Once it's done there is no way to synchronize the two units, so the chances of both receiving the same signal at the same time are remote.
I hope this answers your question.
Bill B.
Listening in since the 60's
Feb 08, 2011 | Radio Shack Pro-2051 Base Scanner
GOT NO MANUEL FOR THE UNIDEN PRO 2055. WOULD LIKE TO PROGRAM NEW FREQUENCIES INTO THE SCANNER..
You can download and print an easy to read aftermarket manual for your scanner here:
http://www.marksscanners.com/97/97.shtml#receive_modes
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
Bill B
Sep 11, 2010 | Radio Shack Pro-2055 Base Scanner
Pro 97 scanner for mclennan County down load
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 19, 2010 | Radio Shack Pro-97 Handheld Scanner
I am trying to program radio shack pro 97 police scanner need live help
nothing to it. press program, enter frequency, press enter, press program to repeat next frequency.
Thanks,
dodgem250.com
Apr 09, 2010 | Radio Shack Pro-97 Handheld Scanner
I need help programming my Pro 97 to listen to fire/police channels in Kitsap County washington
Press manual,enter channel number,then press manual,enter the frequency you want including the decimal point,then press E,if you make a mistake press CLR twice to erase. You can get the frequency,s you want at RadioFreq.com ...hope this helps...
Mar 16, 2010 | Radio Shack Pro-97 Handheld Scanner
I can not get any sound out of my radio shack pro 97 scanner I turn the volume all the way up and hear a light uzzin sound I have it on the weather channel and no sounds my scanner saids all channels...
Nothing's wrong. All of your frequencies have been deleted (pre-programmed PLUS anything you entered yourself).
You'll need to re-enter all of the frequencies to get it working again.
Oct 26, 2009 | Radio Shack Pro-97 Handheld Scanner
Cant get a answer on how to program my pro-97 scanner
here is a quote from the manual; hope it helps you.
1. Press MAN, enter the bank (0-9) and channel number (00-
99) where you want to store a frequency, then press MAN
again. M and the bank and channel number appear at the
upper left corner of the display (for example: M000).
Press FUNC. Then press e or d. The bank number moves in
the direction of the arrow pressed.
Press FUNC. Then hold down e or d. The bank number
moves continuously in the assigned direction.
Press e. The channel number moves upward one by one.
Or, press d. The channel number moves downward one
by one.
2. Press PGM. M changes to P.
3. Use the number keys and ./DELAY to enter the frequency
(including the decimal point) you want to store.
If you make a mistake, press CL to delete a single digit or press
and hold CL about 2 seconds to delete all digits.
4. Press ENT to store the frequency into the channel.
If you made a mistake in Step 3, Invalid Freq. briefl y
appears and the scanner beeps when you press ENT. Start
again from Step 3.
Your scanner automatically rounds the entered frequency
to the nearest valid frequency. For example, if you enter a
frequency of 151.553, your scanner accepts it as 151.550.
May 27, 2009 | Radio Shack Pro-97 Handheld Scanner
Not hearing certain frequincies
not all scanners will pick up the same, the hand held can't pick up frequency as far as the other one.
Mar 11, 2009 | Radio Shack Pro-97 Handheld Scanner
NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
164 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
