Question about Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum
Turbo Tool doesn't spin freely
The brush beater in the turbo tool does not spin as freely as when it was new. Because of this, it does not clean surfaces as well and gets clogged more frequently. I clean it out as thoroughly as I can, even using tweezers or tapping to remove any little pieces of obstruction or dust. Is there a safe way to lubricate it or some other way to restore the turbo spin?
    President:
  • 1,673 Answers
This is air-driven, the only way to clean it is to take it apart. Clean out the bearings and end pieces for the wheel. If it is metal, put a drop of lite weight oil on them, but if plastic, then don'f use oil. Use furniture wax to clean and lube if you need to. It needs to turn freely with no friction. If this doesn't help, then replace it.
Posted on Feb 29, 2008
  • 328 Answers
Also, turbo tools are notorious for not working if the side parts that hold the main turbine wheel and belt in place have slipped upwards. Ensure that each side part has slid down and locked into place. Sometimes the turbine wheel hinges get clogged up with carpet threads which render the wheel useless. By removing this the turbo brush should move freely and not so stiffly.
Posted on Apr 19, 2008
Turbo tool used only once or twice, already brush moves so slowly it stops when I try to use. Brush can actually be stopped by hand. Manual says nothing at all about the brush ie. HOW to take apart to see...
It takes a lot of suction to spin the brush. First make sure the suction is good. Make sure the bag and/ or filters are clean. Replace if necessary. Most turbo tools can be opened up to clean. Most have a lever that allows you to open it up to clean hair, dust, etc from the fan and fan shaft and other areas inside the tool. The tools pick up a lot of hair and debris and some will wrap around the moving parts building pup to the point the brush will not spin fast enough. The same thing can happen to the brush roll on your vacuum so be sure to clean it too and replace the belt at least twice per year.
Oct 31, 2013 | Eureka Vacuums
Bissel 3760-4 brush motor doesn't turn on
Hi Tim. I understand the brush is turning & belt is fine. You may want to remove and reseat the canister. If this doesn't work, you'll want to have one of our Authorized Service Centers inspect your vacuum.
Here's a link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 19, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
I have an old fantom thunder upright and need to take the bottom off it to see what is stuck in it. I don't know how to do this.
moz-screenshot.jpgI found a manual for the Fantom Stick Vac, model FS801 (your model may be different).
For "Cleaning Air Driven Turbo Brush", it says:
  1. Remove the turbo brush from the hose or extension tube.
  2. Slide locking latch forward, then tilt the top housing of the brush upwards. The top housing is hinged and will tilt up approximately 45 degrees only.
  3. There may be some dust, lint, hair, etc. on the turbine wheel. Remove as much of this as possible.
  4. You may also use the unit's hose with the crevice tool attached, and use the vacuum to remove any additional debris from the turbine.
  5. Ensure that the turbine wheel moves freely by rotating it with your finger. If the turbine does not rotate, call Customer Service for help.
  6. Once clean, close the top cover of the turbo brush and slide the locking latch towards the rear of the brush to lock.
There is also an image in the manual that might help. You can download the manual for free here.
Hope this helps!
Mar 03, 2011 | Vacuums
I have a bissell easy vac and the metal part that spins the rubberband and brush keeps overheating and burning all the belts I replace. What should I do?
Sounds like the beater brush is frozen and won't turn. Remove the beater brush and clean off all debris, especially at both ends. You will find a square(?) piece at each end of the beater brush that holds it in place. This need to turn freely. Put a little WD40 on these where the center rod of the beater brush enters the small holders and turn by hand until they turn freely. Once this is done, assemble with new belt, making sure the belt is put on properly. If the belt is missing and you need to replace, I would still do the cleaning on the beater brush. It should move freely when you turn it by hand.
Sep 13, 2010 | Vacuums
My bissell helix cleanview vacuums brush doesn't spin
Sep 12, 2010 | Bissell Cleanview Helix Deluxe Bagless...
My bissell vaccum doesnt work even though i've replaced the belt but when ever i turn it on i get this rubber smell...can anyone tell me
Sounds like the beater brush that the belt controls is frozen in place and needs to be cleaned. Remove the brush and clean any debris that you find on it AND at either end. The end pcs are used to hold the ends of the brush stationary while it spins via the belt. When you get the brush off, spray both end pcs with a bit of WD40 and work by hand until they spin freely. This should solve your problem.
Sep 12, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
I have a problem with my model 6585-3 bissell upright powerforce bagless turbo with turbo brush vacuum The brush has quit spinning upon removal i noticed that one side of the brush was free to spin the...
Hair and dust build up under the end caps of the brush roll and cause friction. Replace the brush roll and belt. Be sure to clean the brush roll frequently after use.
Jun 24, 2017 | Vacuums
Power head on epic 6500 does not work, is there a belt?
This is a bot of a blind guess, I don't know the model. But most power head cleaners I have worked on use the suction of the vaccuum to spin a turbo fan in the head (like blowing a child's windmill). The head not spinning is usually because there's not enough **** to spin the turbo fan. Check for:
Gummed up brush bearings (dirt or damp) making the brush harder to turn than it should be.
Poor suction caused by a blocked or partially blocked pipe.
An obstruction that is tactchin the beater or the turbo fan.
Blocked filters on the cleaner, reducing the **** and thereby not providing enough vaccuum to spin the beater.
Jan 18, 2009 | Electrolux Epic 6500 Vacuum
Bissell Lift-Off(R) Revolution(R) Turbo Upright.
If you have a rubber smell, then the belt is slipping, does the brush roll turn freely while holding the ends? If not then replace it, part #2036619, if it is ok, then the belt has strectched and is slipping under load, part # 2106679, Style 8.
Jan 20, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Dirt Devil Vision Turbo W/Bonus Upright Vacuum Vacuum Logo
306 people viewed this question
Top Dirt Devil Vacuums Experts
Jim Parker
Jim Parker
Tim Venetis
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
