Question about ASUS A6U Notebook
Will not reinstall
My harddisk has one newly formatted and partitionated FAT32 partition.
When i use the recovery disk, i get error 1802. (= cant read image).
Tried to install from a XP-CD, but it stopped 60% finished.
Tried to install winME, but it also stopped.
Tried to install a Linux, but got "Kernel panic" .
I have loaded BIOS default.
I need help. !!
  • coehlen Feb 25, 2008
    One of the ram-blocks were bad - removed it - now all OK.
    Best day for long. Thanks.
  • Anonymous Mar 27, 2014
    I have an old D160 which I tried installing linux on but it would just hang for hours on the load screen. So I decided to just do a factory reset but I need the disk and Dell no longer has it. Is there anything I can do?
    Sniper:
  • 67 Answers
Download, burn and run the bootable memtest cd or dvd, boot from it and it will run tests your RAM.
http://www.memtest.org/
I have run into similar problems with faulty ram.
Posted on Feb 23, 2008
1781 - disk failure problem startup for HP nc 6220
This happens if the harddisk data is corrupted.
Hard disk has a data that the computer reads first before going to the operating system. To fix this to to do a debug or do a full format of the hard drive. Try to run a diagnostics first by pressing the F9 upon the HP logo. if it does not report any error run a recovery by pressing the F11 upon the HP logo then choose the SYSTEM RECOVERY. then simply follow the prompts to revive your computer to the original factory default. Do this a couple of times. If this will not work then most likely the recovery partition is deleted or corrupted. If you can still see the HP RECOVERY IMAGE, then go to START > COMPUTER / MY COMPUTER > right click and choose MANAGE > DISK MANAGEMENT > look for the HP RECOVERY IMAGE > right click and choose > SET AS ACTIVE PARTITION, then reboot the computer then simply follow the steps for the recovery.
Apr 22, 2011 | Computers & Internet
Conversion of file system
The conversion is actually necessary if you are going to use this device with Windows 7. Windows 7 will not read a FAT32 partition. All drives can be converted to NTFS, just remember the conversion is one way. It cannot be changed back without a complete format.
Jun 24, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Jul 30, 2009 | HP Computers & Internet
Acer asire 5920 wont boot up cant get to windows to type anything in just a black screen asking for password or harddisk password. have acer aspire 5920 system disk it works asks for recovery disk 2 runs a...
For the psswords i can recomend to reset them from BIOS but to do that you must first know them. The problem with recovery disks is solvable if you boot from an XP disc and format the C: partition in NTFS file sistem and when it starts copying files to install the windows stop the installation ( F3 or press the power button for more than 4 seconds.. don't worry you will not sustain disk damage... done it myself with the same notebook for a dozen times ) After formatting the partition C: try recovery again and it will work.
NOTE: for the formatting of the partition you must set the HDD mode from AHCI to ATA witch permits the XP setup utility to "see" the HDD. If it is set in AHCI mode the setup utility for windows XP will not detect youre HDD
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Partition parameter
From the data you provided, the D drive is deleted and is newly created. But it is not yet formatted. So the data is virtually deleted. Why I said virtually is because, the data is still there on the drive physically and you can recover it using third party tools like OO disk recovery tool. That is why partition magic is still showing data on it.
And it is also obvious that the task which Partition Magic started (splitting drives) is not finished properly. That is why K partition is incorrectly formatted. It is natural that it asks format of D drive because D drive belongs to no file type and it must be of FAT32 or NTFS or other file system.
The solution for your problem is try recovering your data on D drive using disk recovery tools. Then format it using FAT32 or NTFS. Format K drive also in FAT32 or NTFS. Use either partition magic or Computer Management. Since already PM caused problems on your computer, try computer management. It is safe.
Jan 20, 2009 | Microsoft Windows XP Professional
98 loading error message
When you format something you WILL lose all of the data that was there. I would also recomend upgradeing to XP, 2000, or NT. You may need to reinstall the OS. If you need instructions ask me and I can help.
RCF
May 29, 2008 | Microsoft Windows 98 for PC
CHANGED HDD FORMAT
The best thing you can do now will be to obtain a windows Startup disk and use fdisk utility to format.. If you are using a seagate HDD then you can also try seagate disk manager. Another option will be to boot from win XP CD and start the setup.. During the setup it will at some point it will provide you the options
1)format using NTFS
2)FOrmat using FAT
3)Format Using FAT32
From these choose format using FAT32. Thats all it will be formatted.. Afterwards you can use a tool like Partition Magic to resize and create more drives on the HDD.
Sai.
Mar 21, 2008 | Toshiba Satellite P105-S6104 Notebook
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
ASUS A6U Notebook Logo
78 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
