Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Ctc 195 series rear projection T.V. piture quality
While watching a movie on my tv the screen all of a sudden distorted into rainbow colors i turned it off and it wouldnt turn back on i replaced the fuse in the back regaining power, but my picture is bowed into the center what is wrong with it and how do i fix it?
Picture is distorted most of the time.
  • powcon Feb 27, 2008
    to slinteriors.
    re picture distortion on my 56" rear projection tv.
    The picture is bowed toward the center and the red, green and blue lines are showing.
    if i leave the Tv on it will eventually fix itself until i turn it off again.
    I do not know how to post a pic. to you but I hope this is helpful in diagnosing my problem.
    Thanks for your help so far.
  • JVC Master
  • 8,617 Answers
Can you post a picture of what the video is doing? It shounds like a pincushion problem, but it may be convergence amp as well. A picture could clarify it for me so I would know which direction to assist you in.
Posted on Feb 24, 2008
  • Sonny Berry
    Sonny Berry Feb 27, 2008
    Sounds like solder issues. I would try soldering the flyback , horizontal driver and convergence ICs. Rca has been known to have solder issues. Basically any solder that doesnt look shiny re-solder. It also helps to look at the solder with a magnifying glass check for hair line cracks.
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
CTC 195 series
Horizontal output transistor is needing replacement for sure and quite possibly the flyback as well
Jun 29, 2008 | RCA P56950 56" Rear Projection Television
Ctc 195 sereis tv
Try unplugging your set, If you didnt save the changes this should reset it back to default settings. If that desnt work, you will need to go bak into the service manual and adjust the horizontal size. Just write down anything you change so you can revert back if you have too.
Jan 22, 2008 | RCA P56950 56" Rear Projection Television
It's most likely a failure of the convergence amp and some other power supply problem in the convergence circuit by the sounds of it... Your unit takes an STK730-130 and some 750k 1/4w resistors for the yoke return. I would bet two or more of them are out of value, at least R19702 and R19703... There are also two diodes Cr19710 and Cr19709. P/N# 164590 which commonly open under a load and are recommended to replace anytime the convergence amp is replaced. Also check Q19700 (Bc457) which crosses nicely to an NTE123a...
Not real expensive in a reputable shop - just a pain this time of the year.. I would recommend getting it repaired, it's worth it..
Bill
Dec 19, 2007 | RCA P56950 56" Rear Projection Television
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
RCA ctc 195 series
this tv most likely has a shorted horizontal transistor and transformer. Now that you have a heads up on the problem it's best to contact your local tv rep. John
Sep 13, 2007 | RCA P56950 56" Rear Projection Television
Rca ctc 195 series
Before anyone changes those setings you should write them down.
Apr 15, 2007 | RCA P56950 56" Rear Projection Television
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
149 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
