Question about Cuisinart SS Grind Central, removable bowl w/ cover Grinder
Stopped working I was grinding beans this morning and my grinder did not finish grinding what was in the bowl. I kept trying in pulses. and then it stopped working. I smelled a hot electric smell. Now when I depress the grind button it won't grind. I've let it cool down with no luck. I should mention I had filled the bowl almost to the top, so I must have exceeded it's capacity. This grinder is only a couple months old. Did I kill it? Thanks!
  • Anonymous Apr 11, 2009
    kill it?
  • 4,889 Answers
Not to worry. This grinder can be filled till the top. This will be covered under warranty. Just give a call to Cuisinart and they will fix it for you
Posted on Feb 23, 2008
How long is it safe to continuous grind
I burned mine out and had to repair it by trying to grind a pound of beans. I say pulse works the best--2-4 seconds each burst. One can grind 5-10 seconds but it heats up inside and in my case, contact melted (metal) from ongoing current to motor via switch. I rigged it but would recommend staying under 10 seconds. pulsing works best in coffee grinders and food processors.
Jan 20, 2013 | Braun KSM 2 Electric Blades Grinder
Our bean grinder has stopped grinding. It spins but the beans do not grind. The machine works fine on the ground coffee option.
Did you put water in the grinder by mistake? If the grinder is wet it won't grind anymore,have to cleaned the blades physically .
OR are you using the beans from the fridge? It's a NO NO.
Jul 30, 2010 | Saeco Magic De Luxe 30092 Espresso Machine
Can this be fixed??? my grinder stopped grinding ????
Try to remove all coffee beans first by hand, then s*ck all remaining with a vacum cleaner.
Undjust the grinder to more gross coffee.
Try to work back again the grinder. If it is working then adjust back again to your previus postion but remeber that you can go back again one step at the time so the grinded coffee wil not blocked the grinding plates.
Good luck
Mar 30, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a gaggia syncrony logic.The coffee beans are not going to the grinder so the grinder is just spinning,we have cleaned the machine and cant tell if something is stuck in it or what. cand you help?
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Oct 27, 2009 | Coffee Makers & Espresso Machines
Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Mar 23, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My Saeco won't grind the beans
There's moisture in the grinder & it's clogged - just dismantle the grinder & clean it, then ensure you don't splash water into the bean hopper when you fill the water tank.
Mar 29, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Aug 21, 2007 | Cuisinart DGB-600 Coffee Maker
Cuisinart SS Grind Central, removable bowl w/ cover Grinder Logo
455 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
