Question about Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 won't acknowledge memory card
Keep getting error message on memory card, will take one photo, then the error comes up. Auto focus also not working right. Took to camera shop but they can't say for sure if a pin is bent...but that doesn't appear to be the case by simply looking.
  • 1 more comment
  • NUTZ119 Mar 09, 2008
    unable to use card message
  • masyura May 27, 2008
    I got the same problem ('unable to use card' error) with my dslr-a100 =( don't know what to do, want to check the flash card via external flash reader, but it seems the camera needs to be fixed, not flash card.
  • Anonymous Nov 26, 2008
    Got the same fault. Sent it to Sony's "specialist" here in sweden and came back after 2 month (ans a lot of nagging) with: "the CF slot pins where bent, adjusted".
    Same problem still exist for me after the return, and I cant se any bent pins, tried 3 different CF cards all working in a Canon EOS and in the USB reader on the PC.
    Genius:
  • Sony Master
  • 1,689 Answers
I would suggest that you give the camera to Sony service to have a look at it. The regular shop would not have the proper test facilities to properly diagnose any in depth problems with this type of camera unless they were an authorized contracted service rep. The problem may be involved.
Jerry G.
Posted on Apr 12, 2008
Sony SLR a230 Camera - I'm getting a camera error come us a lot but it doesn't tell me what the error is, I'm on AF - Auto normally
can you tell me how to solve memory card error for Sony SLR a230? they asked me to format it but i've taken thousands pictures. please and thank you
Oct 01, 2010 | Sony Alpha DSLR-A230 Digital Camera
I keep getting a memory card error message. i am trying to scan photos to my memory card via my hp photosmart c5180
Some computers will not acknowledge your flash cards. Depending on your flash card, your printer & computer to make sure they are compatible. Try opening your computer Icon to see if card is accepted. then click in your card to see if any file are in. You may have to load your printer software again..
time for the Geek to help!!
Jun 29, 2010 | HP Photosmart C5180 All-In-One InkJet...
Alpha DSLR-A100 Digital Camera: i got problem with memory card. keep showing the m...
not all memory cards fit sony alpha perhaps you have bought wrong cd.try using your sd slot
May 06, 2010 | Sony Alpha DSLR-A100 Digital Camera
My camera tells me it's full when it shouldn't be. I have a 2gb sony memory stick pro duo for my Sony Alpha 100 camera. Today, I shot about 80 photos and it said it was full, but I had just deleted all...
hi, sometimes old photos tend to stay inside due to some defect or settings. instead of deleting photos. format the card once before you start clicking the photos. formatting can be done in PC or in your camera. if this does not solve the problem. please revert back to us. thank you. sweet rascal
Oct 18, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
I have had my sony for about 2 years and suddenly last night while shooting pictures, the message "unable to format card" appeared on my screen - what can I do?
It's just the memory card. This error message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
What do i do when I turn on my sony alpha 100 and it tells me unable to use but I formatted it and it still says unable to use???
It's most likely a problem with the memory card. This message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 06, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
I can't format any memory card (CF) with my Sony Alpha 100
you have a lock on your memory card check that !!
Jan 03, 2009 | Cameras
Sony Alpha DSLR-A100 Digital Camera Logo
473 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
