Question about Lite On LVW-5115GHC+ DVD Recorder
CD Rom does not work HELP!
Cd-rom with yellow exclamation point ! will work with boot cd only,and is a NEC ND1100a and their download driver does not work Thanks, Jack
    Scholar:
  • 110 Answers
Typically these drives don't need an extra driver, as windows detects them automatically. The first thing I'd recommend trying is to right click it's entry with the exclamation mark and uninstall it. Once uninstalled, reboot the pc. It should install correctly then. If it doesn't, there may be an issue with the IDE controller it's connected to (usually a bios setting determining raid/ide mode).
Posted on Feb 23, 2008
    President:
  • 1,944 Answers
Are you talking about an NEC cd drive on a PC running Windows by any chance?
  • Damen Wong
    Damen Wong Feb 23, 2008
    or the LVW-5115GHC+ DVD Recorder
  • 4,889 Answers
Looks like a compatibility issue. Go to device manager , Right click on the device and click update driver. Windows will automatically find and update the device with the best driver available.
    Brigadier General:
  • 3,614 Answers
Try un-install it first and boot the your pc without it. then off you pc when it completely loaded.
attached the cd rom again and be sure it has separate IDE cable and must a secondary master. then boot again you pc.
Let me know what happen next..
thanks,
    Genius:
  • 1,019 Answers
switch off-Unplug unit remove from mains for 30 minutes.
Plug back in And see if the problem has been resolved.
Mike @ Compurepair.
Where can I find the driver
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps you
Feb 29, 2012 | NEC DV-5700A Internal DVD Drive
DRIVERS OF LG CRD 8400B (CRD-8400) Internal 40x CD-ROM Drive
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
http://download.cnet.com/lg-gcc-4480b-combo/3000-2122_4-10203023.html
http://www.driver-fix.com/scan.php?id=scan5&key=2
hope someof this helps
Oct 11, 2011 | LG CRD 8400B (CRD-8400) Internal 40x...
Optiarc dvd rw ad-5260s ata device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
or if its the drivers
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question or exclamation mark ? ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
http://www.opendrivers.com/companydriver/2165/optiarc-free-driver-download.html
you will need to select your operating system
hope this helps you
Aug 28, 2011 | Sony NEC Optiarc Sony Optiarc Black 8X...
I have a nd-1100a and a lite-on ltn4865 48x max. They both have a code 41.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 10, 2011 | NEC ND1100A Internal IDE DVD-RW 4X+ Drive...
My computer list the cd-rom but have exclamation points by both units. the error code 41
Hello
A yellow circle with a black explamation point indicated that the device is not funcioning correctly. This is usually resolved by upgrading the firmware/drivers for the device. I went on samsung.com and found the latest for your CD-RW drive and have included the link below.
Please click Firmware in blue on the page and then download the latest. It is reccomended you create a system restore point prior to installing in the unlikely case that the install causes system instability.
http://www.samsung.com/us/support/downloads/SM-348B
If that happens you can press F8 as windows boots and select boot into Safe Mode. Then go to control panel, system, device manager, select the device, properties, driver, and hit roll back driver.
Hope this helps Please vote if so :) Have a great day
Jan 26, 2011 | Samsung SM 348B CD-RW/DVD-ROM Combo Drive
Dvd does not work. Light blinks but not seeing it . is there a driver i need or what do i do to fix this
You must determine if the problem is the media you are using (CD, DVD) or the drive itself. (CD/DVD Rom)
First see if the driver is installed for the CD/DVD ROM by Right clicking My Computer and choosing Properties, Hardware, Device Manager. Clikc the plus sign next to DVD/CD Rom Drives to see if there is a yellow exclamation point, or question mark. This means you need to install the correct driver. If there are no yellow exclamation marks or question marks your driver is installed properly.
Next try playing difffernt CD's to see if any of them work. Confirm they are good CD's by playing them on another device, then try them on your Compaq. If the Cd's play on another device you may possibly be experiencing read errors on the CD/DVD Rom drive. Try using a CD Laser Cleaner that will clean the laser head of the CD /DVD Rom. it looks like a CD with small brushes on the music side. This may solve a read error problem. if that does not solve your problem you may need to replace the CD/DVD Rom drive.
Jun 14, 2009 | Compaq Presario Notebook
DVD CD ROM
yellow triangle means conflict error try updating the driver or you may have to reinstall the device
Apr 03, 2009 | NEC CDR-84 (CDR-84-1) CD-ROM Drive
DVD/CD-ROM PROBLEM
The yellow exclamation mark means that the driver for the DVD/CD-ROM is corrupted. You will need to find the drivers for your drive and re-install it. This should be easy enough to do: find the brand name of your drive and go to the website of the manufacturer, then locate their drivers page and find the specific driver for your product, then download and install the driver and restart your computer and the drive should work.
Please rate if this works for you, Thanks!
Mar 10, 2009 | Microsoft Windows Vista Home Basic for PC
Cd/dvd rom not working
go into device manager and see if your drive is listed or has an exclamation point beside it.if you dont know how to open device manger go to start menu and click help and search device manager.if there is an exclamation point ! click it and it will tell you the problem.you may need to download a new driver or reinstall the old driver. the only other possibility is the drive is dead :(
Nov 14, 2008 | Dell Inspiron 1501 Notebook
Lite On LVW-5115GHC+ DVD Recorder Logo
53 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
