Question about Epson LX-300 Matrix Printer
Custom size doesn''t present on your driver on Form to Tray Assigment in
I purchase Epson LX-300 . I add custom form width 4.00 in and height 0.5
in. (form name Tags) in the Server Properties. The problem is the custom
form, Tags, doesn''t present on your driver on Form to Tray Assigment in
Devices Settings
  • humbertopr Feb 23, 2008
    software=Microsoft Access 2003 OS=Windows XP
    President:
  • 1,944 Answers
From what program are you trying to print? Which operating system are you using?
Posted on Feb 23, 2008
    Brigadier General:
  • 3,614 Answers
When printing on multi-part forms, thicker-than-normal paper,
labels, or envelopes, make sure your software program settings
keep the printing entirely within the printable area.
thanks.
  • micromaster
    micromaster Feb 23, 2008
    therfore you you set the paper size into 4x0.5inc. and it use a roller type, when you print it it could out of range.
  • micromaster
    Try on the usual way. Put everything with a limits, even your printer have that.
  • Epson Master
  • 19,396 Answers
Hi, I can't understand what "Custom size doesn''t present on your driver " means. the drver is just the piece of sofware used by windows to make your printer work. Custome size setting should have nothing to do with the driver.
  • Ginko
    Ginko Feb 23, 2008
    I any case there is a well known problem is setting page custom size for your printer. LX 300 default size is letter. It also works well with a4 and other formats. Headaches will start when you try to use some other page custom size(you have similar troubles with fonts custom size. No matter what Epson said when they promoted the lx300 (on Win 98), which was advertised as fully customisable font and page size. Not all sizes are accepted under XP. depending on what size you enter, you will get the printer resetting itself to letter or a4. You can read about the same problem in many tech discussions, for example here and here.
    Depending on which paper size you are trying to use there may be no effective solution for your problem.
    Naturally first you have to ensure that you used paper custom size correctly.This may have different ways to be done, depending on Operative System used (eg. Windows xp home) and eventually software (you can change paper size from MS Word or Photoshop for example or from printer properties in control panel). I suggest referring to user guide and ensuring you followed right procedure.
    If you still cannot use your custom format then the only thing to do is using a standard similar format(or trying to). For example a6card, which is 6x5 inches.If you are using XP I am not sure you can use a format that is not letter or a4 on your printer.
  • Ginko
    Ginko Feb 23, 2008
    Here is service manual for your printer.
    My last suggestion is in any case updating windows driver for your printer. here is the driver page for epson impact. Just select your model and download latest drivers. You can also try drivers for similar printers lx300 and lx300ii. If they do not work reinstall back standard driver for lx300+.
    Good luck
I want to add fanfold 8.5*12 option on wep 800DX printer settings.How to done it?
This is the answer I found on the website for this printer. I do not have any knowledge of this printer other than to look for information on the Internet.
How to do the custom page setting with Windows XP
Follow below steps for custom size of page in WinXP. 1. Go to Start - setting - Printers and Faxes 2. Select the printer for which you need to set the page 3. Click on File - Select Server properties - 4. Select "Create New Form" , and name the form. 5. Change the Height and Width of the forms as per available paper size. 6. Press Apply and save the form. 7. Now you can able to see the form name in the driver setting.
Mar 06, 2014 | Microsoft Windows XP Professional
Am running windows7 and when i try to add a form with 21" width and 30.50" height my form is not added.
The form width you are trying to create is wider than the T6215 is able to print on. The maximum page width that you can print is 13.6 inches, if you try to create a custom size paper wider than 13.6" Windows will not show you this form within the T6215 printer driver. As you can not physically print 21" wide you do not need to define a paper size this wide. Simply create a paper size which reflects the maximum print width or 13.6" You will then be able to print the maximum width the T6215 is capable of and also see this form in the printer driver.
Jan 03, 2011 | Tally T6215 Matrix Printer
Hello, I have an invitation that is 4in wide x 9 inches in height. I want to print something on it, but not sure how to get my printer to recognize that I am using custom size paper. It keeps printing on...
In addition to the wide variety of standard paper sizes available for this printer, you can use custom size paper in the Tray 1 (MPT).
The size range for custom size media is as follows:
    Minimum allowable page size:
    89 x 140 mm (3.5 x 5.5 in.)
    Maximum allowable page size:
    216 x 356 mm (8.5 x 14 in.)
  1. Open Tray 1 (MPT).
  2. Insert the custom size paper and adjust the guides to match the size of the paper. Place the side to be printed facedown with the top of the page entering the printer first.
  3. When the front panel prompts you to confirm the type and size of paper:
    1. Scroll to Change by pressing the Down Arrow key and press the OK key.
    2. Scroll to the correct paper type and press the OK key to save your selection.
    3. For the paper size, scroll to Custom and press the OK key.
    4. Select Set Custom Width (W) by pressing the OK key.
    5. Press the Down Arrow or Up Arrow key to scroll to the desired value for X and then press the OK key.
    6. Scroll to Set Custom Height (H) and press the OK key.
    7. Press the Down Arrow or Up Arrow key to scroll to the desired value for Y and then press the OK key.
  4. Select the custom size in the printer driver.
  5. Windows 95 / Windows 98 / Windows Me PostScript driver: On the Setup tab:
    • After you select the Multi-Purpose Tray and the tray displays Custom to indicate that it has custom size paper, enter the dimensions of the custom size paper in the Width and Height boxes.
    • If you select Automatic for the paper source and select Custom Size for the paper size, enter the width and height values of the desired custom size paper in the Width and Height boxes. The values for width and height are initially 0. If you previously entered information in the boxes, the values are automatically entered.
    Windows NT / Windows 2000 / Windows XP PostScript driver: On the Paper/Quality tab:
    • If you select Choose Specific Tray, select the Multi-Purpose Tray.
    • If you select Automatic, you can select your custom size from the Paper Size drop-down list.
    • Click My Custom Sizes and highlight the custom size in the Current Selection list. The Name, Width, and Height boxes display the details about the highlighted custom size and the sample image changes to represent a scaled version of the custom size.
    • To create a new custom size:
      1. Click New.
      2. Enter the new name in the Name box.
      3. Enter the dimensions in the Width and Height boxes. The sample image changes to represent a scaled version of the new custom size.
      4. Click Save to add the new size to the list. Click Cancel to exit without saving the new custom size.
      5. To exit, click Close.
    • The My Custom Sizes box lists existing custom sizes that are supported by the current printer. Since these custom sizes are saved in your computer's operating system, they are available for you to select in your applications.
    • If you create a custom size in certain applications, the driver lists the custom size automatically.
    MacOS 8 / MacOS 9 driver:
    • In the Page Setup dialog box, click on Page Attributes, and select Custom Page Sizes. Then press New to enter a new custom page size. A dialog box appears where you can enter the width and height, margins, and name of the custom page size.
Jan 19, 2010 | Xerox Phaser 6250 Laser Printer
Default paper size for all the time
Hi Sabharish,
This setup works fine. But, if you run crystal report from application still is defaulting page size as Letter only.
Can you help me to solve this.
Thanks! Rajesh.
Oct 09, 2009 | Epson LX-300 Matrix Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Can't print custom envelope on HP Photosmart 7280
OK, to make this clearer, I had the same problem on my HP C7180. It seems to be rampant throughout their Multifunction printers.
My Fix, combining several others:
1. Go to Printers and Faxes on your Start Menu. In the Printers window, select Server Properties from the File menu. Use the Forms tab of the Print Server Properties dialog box to view printer forms. You may also see lots of forms that you wish your printer could see, but don't worry, it'll see the one you create now. And be sure when you create your form that you use the narrower dimension for the width and the longer dimension for the height. Usually for envelopes you will print in landscape mode.
2. Select the Create A New Form check box.
3. Enter a new name for the Form in the Form Description For field.
4. Use the fields in the Measurements area to set the paper size and margins. *Use the narrower dimension for the width and the longer dimension for the height*.
5. Choose the Save Form button to save the form. The Save Form button only gets pick-able when you type in a different name than what's there already.
Now go to your document program, such as Word. Make sure the window for the document you want to print is the active window. Select File/Page Setup..., Paper Size Tab, and there select the form you just created from the dropdown list
Still in your document program, select File/Print... then Properties. Select the Features tab, which may be differently named. Under Resizing Options/Size dropdown, select More... and there you'll find your newly created form down at the bottom, under Custom. Pick it.
If you're printing envelopes or other things where the way you view it it's wider side-to-side than it is tall, be sure and select "landscape" in both "page setup..." on your document program and in File/Print.../Properties/Features?Basic Options.
When I did all this methodically, I was able to print my Christmas envelopes. Yay!
Nov 25, 2008 | HP Photosmart C5180 All-In-One InkJet...
Printer is not recognizing the new custom paper size
You also have to create a form the same size in "server properties".
Click on "printers and faxes"
Click on "file" top left of screen, choose "server properties"
Click on "create new form"
type in width and height of paper
(my HP printer will not recognize any paper less than 5' in height and less than 3" in width)
If your create a form less than 5" in height ' and/or less than 3" in width - chances are that's why your printer won't recognize new form. Height HAS to be at least 5" and width HAS to be at least 3"
type in name of new form
save form and close
It should now be in your printer paper options.
Nov 17, 2008 | Office Equipment & Supplies
I have a Stylus photo printer R1900
There are two different ways to create a custom page size within the Epson printer driver on Windows 2000 or XP. The method you need to use will vary depending on what type of driver is installed.
CREATING A CUSTOM PAPER SIZE IN SERVER PROPERTIES
This method will create a new page size accessible by all printer drivers installed in Windows.
1. Open the PRINTERS (2000) or PRINTERS and FAXES (XP) window.
2. Click on FILE, then select SERVER PROPERTIES.
3. On the FORMS tab, place a check beside CREATE A NEW FORM.
4. Input a new name for the paper size. Enter the desired height and width, following the existing format (#.##in).
5. Click SAVE or SAVE FORM to add the new form size to the list, then close SERVER PROPERTIES.
6. Right click on the printer name and left click PRINTING PREFERENCES.
7. Look for PAPER SIZE. (Depending on the driver in use, this will be found on the MAIN tab, the PAPER tab, or under the ADVANCED button). Select your custom paper size from the list.
8. Click APPLY to save this setting, or OK in Windows XP.
NOTE: If your new custom size is not available on the list of preset paper sizes, it indicates that the new size is either too large or too small for the driver in use.
CREATING A CUSTOM PAPER SIZE WITHIN THE EPSON DRIVER
This method will create a custom size within the Epson printer driver only.
1. Open the PRINTERS (2000) or PRINTERS AND FAXES (XP) window.
2. Right click your Epson printer name and left click PRINTING PREFERENCES.
3. On the MAIN or PAPER tab, select USER DEFINED from the PAPER SIZE drop down box.
4. Enter the new custom size and give it a name. Click SAVE to save the new size and OK to return to MAIN.
5. Click APPLY to save the changes (OK in Windows XP).
NOTE: this method is not available when using printer drivers resident within Windows itself. If your printer driver name ends in "ESC/P2" you will need to use the first method to add the new size in SERVER PROPERTIES.
Aug 05, 2008 | Epson Stylus Photo 2100 InkJet Printer
Canon LBP-1210 driver
Pls Do this
start>settings>Print&Fax>selesc Canon1210
Then, file>server properties
In forms check creat a new form and give name Leagalx
Set Width 8.5in Height 14.00in Left 0.50 Ri 0.50 top 0.50 bott 0.50 then save form and close it.
Open the printer properties select forms > change forms
and select the "leagelx". Ok.
You di it
Apr 19, 2008 | Canon LASER SHOT LBP-3000 Printer
Printing on 4x8 cards
Oct 12, 2007 | Epson Stylus RX580 InkJet Photo Printer
Epson LX-300 Matrix Printer Logo
410 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
