19 inch combo Flat t.v
Not getting Channels
    Problem Solver:
  • 6 Answers
Try to press the menu and go to auto channel,,if done and still not working,, your tv need some retouch of leads by the technician in the tuner area. if it still not working, you have to replace the tuner with same code number.
Posted on Feb 24, 2008
2 Suggested Answers
SOURCE: digital labs 19 inch tv/dvd combo
Wish I knew the answer ... I have the same problem after switching to Dish Network (Satellite). It worked fine with Time Warner Cable. I'm suspecting the signal over Dish is analog (NTSC) which is not supported by this particular TV. I wish I still had the box and receipt!
Posted on Feb 01, 2010
Testimonial: "Thanks, I am going to call the company tomorrow and see if they have a solution. If not I am not sure what to do. Thanks for your help."
I want to know how to change the preset channels on my remote
first use the remote to enter the menu and look for channel setup--you should be able to add or delete single channels that way.
Oct 30, 2012 | Curtis CMC13101 Combo
We have connected our 19 inch combo to cable but all we are getting is a blue screen. We have lost the manual for it. The model number is 1710CB. Can someone please let us know how we can fix this problem....
If you have the factory remote,you need to press the input button and change it to Tv.Maybe need to autoscan channels too.If it's a universal remote,there should be a menu button on one of the sides of the TV.Good luck! Greg
Aug 09, 2010 | Televison & Video
Have new tv/combo and the tv shows no signal,we hooked up rabbit ears please help
you need to program the channels of your tv.to do it consult your owners manual..go to the menuand select auto program and the tv will automatic seach the channels
May 20, 2010 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
Digital labs 19 inch tv/dvd combo
Feb 01, 2010 | Televison & Video
Phillips 19 inch TV/VCR combo --no remote--can't change channels
I cannot be sure of the exact model but... Press and hold the TV's volume up and volume down buttons simultaneously. On many older televisions, this opens the device menu without the use of a remote. Otherwise, use the menu button, which you can navigate in a similar fashion.
Also, somewhere should be an input button. Press it multiple times times to switch between various inputs (the input must match whatever input you are using). Usually after these menus are opened you can use vol up vol down to change things.
Jul 13, 2017 | Philips CCC193AT 19 in. TV/VCR Combo
Unable to get channels 14 through 98.
Make sure in the menu that you have the tuner set to Cable Mode, then auto program again. Hope this helps.
Feb 26, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Unable to get channels after Channel 13.
Go into your menu and make sure the tuner is on Cable, then auto-program....Let me know?
Help
you'll need to bring up the menu, under "channels" or "set-up" you will find something called autotune (or manual channel set-up). it will automatically set the channels you pick up.
May 28, 2008 | Philips Magnavox 20MC4304 20 in....
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
