Question about Hotpoint WMA64 Front Load Washer
Hotpoint ultima wma62s
New heater fitted and new module still no hot water everything cold wash
  • 4 Answers
hotpoint ultima wma62s - d67081b.jpg Remove Two pin socket carefully with pliers. Refit of new one is reverse of remove.
Posted on Apr 20, 2008
    Problem Solver:
  • 10 Answers
I disagree with the thermostat answer, as this machine doesn't have one.
It has a thermister down the middle of the heater, from the information given and what you have changed, its more likely to be a broken wire between the pcb and heater, it is quite common for this machine, normally in the area where the wires are bag tied to the tub front b4 they go under the drum to the motor/heater & pump
Posted on Mar 19, 2008
    Novelist:
    Champion:
  • 244 Answers
It possible isnt the heater elemant it will more then likely be your thermostats which are close to your heater element change both i always have so i dont need to go back to a customers house to change the other at a later date m8
Posted on Feb 24, 2008
Does Hotpoint Ultima WF860 need both hot and cold pipes?
Only if you need to have both hot and cold water wash options.
Jan 23, 2013 | Hotpoint Ultima WF860 Front Load Washer
The machine will not fill with water and mesage H20 flashes. What part needs replacing ? I have checked that both hot and cold water supply is fine. Thanks in anticipation
Does it empty or pump if no then fit a new door interlock switch, this makes machine start providing the fuse and elects are okay....
Jan 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
Will this machine work with just a cold water supply
It should work with a cold water supply WF865 hotpoint if it has one connection on the back it is a cold fill machine all new machines are cold fill only hot fill has gone now. hope this helps.
Dec 27, 2010 | Hotpoint Ultima WF865 Front Load Washer
Can a HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN washing machine run off a cold fill only
The simple answer is yes, via a Y piece if it is a hot and cold fill model
The fitting is available from B&Q, or a plumbers merchants
Aug 13, 2010 | Hotpoint Ultima WF860 Front Load Washer
My waashing machine a WMA62 Hotpoint comes on, you
that sounds like your heating element is o/c .... get your heater tested ..01179512835
Dec 30, 2009 | Hotpoint Washing Machines
Hotpoint ultima super silent w f 840 shows fault 03
Code f03 means wash thermistor open circuit, this is normally part of the heating circuit, suggest you test heater and thermistos located in the end of the heater, and replace if necesscary. If heater o/k , then could be bad connection to control module, or broken wire, if still no joy, then call Hotpoint.
Please rate my solution.
Thanks.
May 30, 2009 | Hotpoint Ultima WF840 Front Load Washer /...
F03
Good morning.
Error code F03 means that the wash thermistor is open circuit, this means that the water is not getting hot.
You need to fit a new thermistor first of all, if that does not solve the prob, then you will have to fit a new heater element as well.
You will normally find the element and thermistor located at the rear of the m/c.
Access it by removing lower rear panel
To get the parts, go to-----www.hotpoint.co.uk
Plz rate my solution.
Thanks.
Jan 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint washing m/c WMA62 - door won't open
sounds like you have a blocked pump or discharge pipe
Oct 12, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA64 Front Load Washer Logo
180 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
