Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Problem for Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Maytag MFD2560HES stay at 33 freezer and 50 fridge
By btv94 on Feb 23, 2008
I have this maytag MFD2560HES for about 2 1/2 years.
In june 2007 the problem was that freezer was working fine but fridge was @ 68. So I replaced the evaporator fan motor and fixed the problem.
Since then it happened 2 time that freezer @ 30 and fridge @ 50. Each time it came back up running by itself after one day and now it just happen again.
Recently i can hear the lound noise like bad hair clipper/trimmer from this fridge.
Any help greatly appreciated.
Comments:
Feb 23, 2008
- Just notice about noise. The loud bad hair clipper/trimmer happen every 2 minutes and last about 7 seconds.
Feb 23, 2008
- No leaks
Feb 23, 2008
- Just open back panel and did test as you've mentioned. No oil No leaks and it's dry.
Feb 23, 2008
- thanks for the help I guess I'll have to call service tech.
Solution #1
posted on Feb 23, 2008
Not Rated)
Compurepair
Rank: Wiz
Rating: 84%, 795 votes
Sounds like an electrical fault.
check the balance or levelling of the unit.
could also be the compressor on the way out.
do you have any refigerant leaks ?
Mike @ Compurepair.
Solution #2
posted on Nov 08, 2009
Not Rated)
Redpackman
Rank: Master
Rating: 0%, 0 votes
I've been told by a tech who repaired my MFD2560HEQ this past week that many of this model had a problem with compressor failure. Your symptoms are classic. What you are hearing is the starter relay trying to start a warm/hot compressor by supplying it with an extra jolt of electricity, but because of the faulty compressor (or if you are lucky a faulty relay) that's warm (cool ones start more easily often) is refusing to budge into motion and compress the freon. Maytag, I believe, has a five year warranty on the compressors. They did on mine, but unless you have an extended warranty the labor replacing it is not covered and that will be around 2-3 hours worth. This is the price we are paying for our quest for energy efficiency. Compressors are being built so small and light that they fail much more often than grandma's old, old refrigerator that was built like Fort Knox and ran for 45 years, remember? But we're being energy efficient! Thank you environmental extremists! I wish I could send you the repair bill.
Solution #3
Not Rated)
micromaster
Rank: Wiz
Rating: 82%, 792 votes
your fridge is out of prion there must be a leaked on the tube connecting to the motor..
try to touch the some tube that connect to the motor where prion was loaded, if you touch some oil outside, you better call a repairman to test it, because there's a possiblity when the oil leaks the motor could be broke.
thanks,
Comments:
Feb 23, 2008
- do the test.
Feb 23, 2008
- Some adjustment to the electrical supply from the fridge, the motor make a noise when it oprerates, it could be you got a low voltage or it supply much higher for the volt needed..
Feb 23, 2008
- lucky the motor/compressor is Ok. now it's only a minor problem, you need a service tech to test and calibrate the proper power supply settings for your fridge.
Feb 23, 2008
- That's good until you got a minor problem.
Please rate & hope to hear more again from you soon.
Kindly regards,
micro
Popular Solutions for Maytag MFD2560HES Bottom
Questions and Unsolved Problems for Maytag MFD2560HES Bottom
Do you recommend Maytag MFD2560HES Bottom Freezer French Door Refrigerator?
Answer
Answer
My Maytag French Door, 25 cubic ft., Lower Drawer Freezer, Model MFD2560HES, refrigerator... (More)
Answer
light is on in refrigerator and freezer, but it is not cold. How do I check my fuses? The fan does... (More)
Answer
hinge for the crisper drawer broke. The long crisper drawer flips open and close with hinges on both... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
