Question about SanDisk Sansa e250 MP3 Player
Refresh database fail
My mp3 deleted all of my songs and it keeps saying refresh database fail. i plug in the USB but nothing shows up on the screen. helpp
  • 4,102 Answers
Hi try this for me see if you can put your mp3 into recovery mode if it goes into recovery mode then i tell you what you need to do next ok follow these instructions
1. with mp3 off switch lock button to on position
2. press and hold rec button on left hand side
3 whilst holding down rec button switch mp3 on this should now be in recovery mode let me know if you get this far ok
Posted on Feb 25, 2008
Cannot delete or add music to iriver h10
I had this problem at first too. the only thing you have to do after it's done syncing disconnect it and turn it on. then afterward go through the options till you find database refresh and wait for it to refresh and all your new music should be in it.
Jan 04, 2009 | iRiver H10 MP3 Player
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e280 freezes and can't get songs on
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 19, 2008 | SanDisk Sansa E280 MP3 Player
MP3 needs to refresh DataBase?
You have to many songs a sansa e 250 only holds a certain amount of space so your best bet is to buy a memory card or delete songs so you can add new ones.
sincerely,Britani
Apr 19, 2008 | SanDisk Sansa e250 MP3 Player
Continous refresh database
I've got the same problem too. I read this on another website: 'well firstly drain the battery and then connect it to charge it up a bit. once it has been there for 5min or so take it off and then turn it on>settings>USB Mode>MSC once you have done that connect it up and it should work/recognise the player. i don''t know how this thingy happens but this is just how i fixed mine!' I'm gonna try it now on mine, and see if it works. I've just got to wait now... Good luck with yours.
Apr 10, 2007 | SanDisk Sansa e250 MP3 Player
Try emailing SanDisk technical support team at: support@sandisk.com And ask them for the Recovery Mode firmware upgrade (Also send them the problem the way you posted it here). They should send you a link to some firmware upgrade file. You could also try calling them at: 1-866-726-3475 but an email should be sufficient because, from what I remember, it is just a link to file that you need to download. I hope that helps...
Feb 07, 2007 | SanDisk Sansa e250 MP3 Player
First switch your USB control to MSC. Then turn off your mp3 player and activate the hold icon. Then turn it on while holding the record button with hold icon still being activated. then it will go to recovery mode. Now plug your sandisk into the computer and wait until it says RECOVERY COMPLETE...PLEASE DISCONNECT or when it just says for you to disconnect. This worked on my sandisk, and it hopefully work for you.
Jan 13, 2007 | SanDisk Sansa e250 MP3 Player
ok, mine had the same problem, first go to settings, then USB mode and switch it to MSC, plug it into your computer and it should show up, then format it, this will erase everything but then u can put it back on, after you format it you can switch it back to MTP mode, its alot better, hope i helped
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
Sansa Scandisk e205 refresh Database failed help plz!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
okay, heres wut u can try. try to switch the USB mode from MTP to MSC (in settings, go to USB Mode and switch from MTP to MSC.) And then in the MSC mode connect it to the PC. I dunno bout ur sansa, but my did a Database Reboot, and the computor could see the player. Then u can switch it back to the MTP mode (czu its much mroe comfortable). Although i think the 0.5 gigs are lost forever (i lost 1.5 gigs,)atleast now u can dwonlaod songs on ur player.
Sep 28, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
