Question about Marantz PM7200 2-Channel Amplifier
Marantz pm 7200
My marantz pm 7200 will not turn on after a trouble free year! changed the glass fuse's still no joy? i have been told it could be the transformer?
  • 3 more comments
  • Anonymous Jun 03, 2008
    I had the same problem, where the amplifier was dead, turned out to be the front microprocessor, hope this helps.
  • Anonymous Nov 14, 2008
    another with the same problem has anyone sorted it out yet ?
  • admglvr1967 Mar 19, 2009
    I have no power to my marantz pm7200 amp, have changed fuses but still no lights nothing! is there a possible cause other than the front microprocessor that perhaps i could try myself as this sounds expensive?!
  • Nick Foletti
    Nick Foletti Nov 24, 2013
    Had nothing but problems with this bloody amp,fuse keeps blowing in plug been repaired 3 times. Will not be buying marantz again, only good thing about it was its sound quality.
  • Anonymous Mar 24, 2014
    Marantz PM-48 ticks in and out for 30 minutes, after turning on. Does anyone have a service manual with schematics???
    Problem Solver:
  • 7 Answers
Could be a power supply failure or a Power "On" switch failure.
Kev
Posted on Feb 24, 2008
Marantz amplifier PM68 replace fuse
You don't see any glass fuses? There is also a non replaceable fuse in the power transformer.
Apr 06, 2014 | Marantz PM-68 Amplifier
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
Marantz pm-52 wont turn on
You need to get test equipment to be sure. DVM meter is a fine start
Apr 20, 2013 | Audio Players & Recorders
Marantz pm 7200 loudspeakers do not cut off when headphones pugged in
Some amps have a button which you press to mute the speakers when the headphones are plugged in. Sometimes marked "Speakers on off". If it hasn't then a new headphone socket would not be expensive to fit. As long as the amp producers sound I don't see any future problems. The previous owner may have used the headphone socket a lot, and simply wore it out!
Jul 19, 2012 | Marantz Audio Players & Recorders
Marantz pm 7200 lost sound, only works when volume is up high, still looks like there are no high or medium frequencies.
You have either lost the pre-amp stage or the Main Amp stage. Since you have a problem on both channels it most be a part that is common to both channels. Something like an IC I would suspect.
Oct 31, 2009 | Marantz PM7200 2-Channel Amplifier
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
Marantz amplifier pm-34
the transformer has an internal thermal fuse. If you study the terminations coming out from the internals of the transformer you may notice either a pair of tinned thicker wires or insulated. This may be open circuit. I have often bypassed this internal fuse(they are notoriously common failures) to get a transformer going. You can get a replacement one from a parts supplier if you felt the need. I would just bypass it anyway.:)This may make the amp somewhat "illegal" in the US. We use the MEN (multiple earth neutral) mains power distribution in Australia and the transformer(if melting) would short out to earth and blow the mains primary fuse, the internal thermal is a US requirement.
Jan 12, 2008 | Audio Players & Recorders
Marantz PM7200 2-Channel Amplifier Logo
1,032 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
