Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Minidv reinsert cassette
My camera was saying reinsert cassette on just two of my tapes, later it started to do it to another so I knew it wasn't the tape. I brushed it out inside a little and it started working again. Now not only is it not working but when I put the tape in it won't roll down and once said something about moisture. It hasn't been around moisture but I did blow inside it a little
  • buzza333 Feb 23, 2008
    It's more then that. It's not the tape because it works in other cameras. I don't know if it is something I can fix or if I should take it somewhere.
  • xtazia Mar 16, 2008
    I'm having the same problem. I instert the tape and then it says reinsert the tape. It was playing it for a few seconds or sometimes even minutes and then all of a suddon it would say reinsert tape. It's frustrating and I don't think worth sending it in for repairs. It'll probably cost less to buy a new one.
These are very delicate compartments. i would recomend sending it in for repair . sorry hope this helps.the guides that the tape goes through are outta balance
Posted on Feb 24, 2008
  • 73 Answers
THIS IS A BAD TAPE TRANSPORT PROBLEM
Posted on Feb 23, 2008
Jvc minidv cassette not working display saying end tape does this mean tape has come loose.
End tape means that you have recorded the full 60 standard play or 90 minutes long play and you should rewind the tape or eject it.
Oct 15, 2013 | JVC GR-DVL100 Mini DV Digital Camcorder
I have a Canon ZR90A and started noticing horizontal gray lines displaying across the screen when it plays back. What is causing this?
The most common cause of horizontal lines during playback is dirty heads/tape path. If you have a head cleaner tape, try playing it for about 5 to 10 seconds and then try your tape again. Repeat as necessary. Try not to run the head cleaner for long periods of time because you may wear down your heads quicker (cleaning cassette is somewhat abrasive). If you do not own a head cleaning tape, I highly recommend purchasing one. Sony (in my opinion) makes the best miniDV head cleaning cassette. We use this brand in our repair shop and they last for years. I have posted a link to the particular tape I am speaking of. Your local camera/camcorder shop may have these for sale.
http://www.amazon.com/Sony-DVM12CLD-MiniDV-Cleaning-Cassette/dp/B0000632H7
Hope this helps you.
www.austintelstarservices.com
Sep 12, 2010 | Canon Video Cameras
What is a cassette name of this model
Cassette utilized in JVC GR-D770 camcorder is calls MiniDV
Ask for MiniDV tapes for this camcorder.
Apr 09, 2010 | JVC GR-D770 Camcorder
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
Won't playback. acts like it's locked up.
This may be corrected by fast-forwarding the tape for a few seconds and then rewinding it back to the point where the issue first started. However, if the issue continues, this could be a sign that the video heads are dirty and need to be cleaned. Use a Sony MiniDV head-cleaning cassette (DVM-12CLD) to clean the video heads.
If the movie continues to stop at the same point even after cleaning the video heads, this could be an indication that there is a problem with the recording on the cassette tape. If this is the case, the data on that portion of the tape cannot be recovered.
NOTES:
  • It is recommended that a high-quality Sony MiniDV tape be used for recording.
Aug 07, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Won't playback and menu won't respond. Acts like its locked up.
The screen that says reinsert the cassette.
Tht means the recording protector tab of the tape is on, check the tape, most or f the time there will be a plastic piece tht can be broken off if u need to prevent any thing from recording on it, try covering the hole with a piece of adhesive tape and try recording
Nov 04, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
MiniDV tape stuck inside
sounds like a defective cassette housing, but i have seen problems with jvc decks and camera when tdk or maxell tapes were used. the lids on these tapes seem to get stuck in the cassette housings in jvc equipment. jvc even recommends that tdk and maxell tapes be avoided.
May 24, 2008 | JVC BR-DV3000U DV/Mini DV VCR
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Jan 25, 2007 | Sony Handycam DCR-HC90 Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
169 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
