Question about Dell Dimension 5100 (D51L1) PC Desktop
Trying to put a hard drive into a working computer
HI
I am trying to put the hard drive out of my computer into another computer to try and access its files, I can put it into the working computer but there seems to only be one cable to attach and I can't locate it on the working computer when switched on. Please help
  • 50 Answers
I am assuming you mean a Dimension 5100 (desktop) and not an Inspiron 55100 (laptop). The Dimension uses SATA drives and as such your second, working system will need an SATA port to connect to. You should take the data cable from the non-working system with the drive since, if there is an extra SATA port on your working system, it will more than likely not have a cable attached to it. Each SATA port only supports the connection of a single drive. There may not be an additional SATA port on the working machine, in which case you're SOL (unless it uses the same HAL as the other, but that's another story).
Posted on Feb 23, 2008
Hi there, my TrekStor external HD model
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program called asoftech data recovery to recover your files.
http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
Sep 05, 2011 | Delta & Single Handle Shower Faucet
External harddrive not recognized by my computer. it worked fine for a week and then all of a sudden stopped being recognized by the computer. Do you have any idea why this would be. It is a windows vista...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/adr/
May 24, 2011 | EDGE Tech Corp Edge 500GB DISKGO 2.5in....
Hi I have WD2500XMS and it does not detect by my laptop, could you help me
May 22, 2011 | Western Digital WD Passport 250GB Portable...
My hardisk is unable to detect by the computers?? Please help!
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
May 10, 2011 | Computers & Internet
Iomega media network hard drive not accessible
Use this file recovery program called asoftech data recovery:
You can find it in magazines or on a internet...
It is a simple, fast program which thorough scan the computer, which allows you to recover lost files
May 03, 2011 | Iomega Home Media Network Hard Drive 500...
I have an external hard drive 120GB , unfortunately it fell down, my PC can no longer recognize it, is there any possibility to retrieve all the files stored in it tnx
May 02, 2011 | Computers & Internet
Nx2 hard drive case power lite on (red) but the hard drive does not run. Green operation lite never illuminates. All cables check good. Removed and replaced with another hard drive; same results....
Apr 27, 2011 | NexxTech 1 Bay USB 2.0 External Drive...
Hard drive cant be accessed.
Hi welcome to Fixya, there are more than one reasons why the hard drive cannot be access. First you should make sure the hard drive is properly connected, if the problem still exist you should take the hard drive out of the computer and put in into another computer that you know is working. If the computer boot that mean it is the connection in your computer is faulty. If is does not boot that mean the hard drive if faulty and should be replace. Thank you
Jun 03, 2010 | Western Digital Caviar SE16 WD5000AAKB -...
Hi, my passport worked fine a couple of days ago whilst i was transfering data to vista. Today when trying to access it, it doesnt show up, it shows local disk but not as WD, and you cant see any...
First thing to try is other usb devices as well as trying the drive in a different port. Preferably one away from the original to make it use a differeant hardware controller inside your computer. Also try unpluggin all usbs and rebooting a couple of times.
And try your drive in another computer to make sure it is working. if it isn't it may just be the enclosure electronics are the problem. If you have important stuff on it then you can try taking the drive out of that and putting it into a universal usb drive enclosure to get it up and running again.
Oct 23, 2009 | Western Digital Passport 320GB External...
Startup repair cant find problem on my laptop and wont let me on
hi dear
Remove the hard drive and connect it to any other working computer using an external USB enclosure. You should be able to see the hard drive in My Computer.
Try accessing it as a regular hard drive.
It is possible that you’ll be able to see files but will not be able to access them. In this case try taking ownership of the files.
or just trying to reinstall your windows
oke
Mar 22, 2008 | Acer Extensa 500T Notebook
Dell Dimension 5100 (D51L1) PC Desktop Logo
60 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
