Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima Washer/Dryer Supersilent....
Has stopped mid cycle and showing F-05
Please can you tell me what this means?
My email address is tinadow@btinternet.com
Many thanks in advance
My washing machine wd860 is not working properly i am getting the tap sign on the machine
Posted on May 26, 2008
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Posted on Feb 24, 2008
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
Machine stopped mid cycle with water still inside and the panel is saying FO/5
F05 means you have a pressure switch fault, check the pressure chamber or pipe also the wiring from the switch. For more Hotpoint, Creda or Idesit error code definitions use this link
Mar 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
Stopped mid cycle with the code F 05 flashing up, it has been tried since with the same thing happening. Not sure what the code means?
F05 means pressure switch jammed on full.
You need to locate and clean pump filter, if not at bottom front of washer, then remove lower rear panel, remove large black hose on bottom of drum, remove and clean filter inside hose.
Fit back and test.
Mar 02, 2010 | Hotpoint Aquarius WD640 Front Load...
Error Code F-05
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit back and test.
Please rate my solution.
Thgankyou.
Feb 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima washing machine is showing a fault
F 05 normally means there is a blockage or a fault with the pressure sensor. The common place for blockage is in the black pipe from the drum to the pump as it has a filter in here and clogs up. remove the pipe and clean the filter out and remove gunk from the pressure sensor on the side of the pipe as well. If that does not fix things the pressure switch could be faulty itself
Sep 13, 2009 | Hotpoint Ultima WF860 Front Load Washer
Cycle ctopped and is flashing f 05
F05 means pressure jammed on full.
Check pump for blockage, or filter if waher has one.
Thanks.
Jun 21, 2009 | Hotpoint Ultima WF865 Front Load Washer
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Feb 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
F-05 error message on Hotpoint 860
i would say there is some thing wrong with the pump
Nov 22, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
329 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
