Mitsubishi HP1080P WD73733
I need help adjusting my color settings. Can you help?
  • Larry  Dillon
    Larry Dillon May 11, 2010
    In color settings, are you meaning the convergence? What model number is it. Why are the settings out. Was anything done to the set?
    President:
  • 3,130 Answers
Was the set new? Color problems can be a bad light engine or a bad color wheel. Do you have the owners manual for this TV set? If Not i will try and leave you a link for one.
Posted on Feb 27, 2008
How to reset lamp timer on Mitsubishi tv model wd73733
  1. Turn on the projector
  2. Press the < > and Power buttons at the same time for about 3 seconds on the control panel.
May 05, 2017 | Mitsubishi Televison & Video
Mitsubishi tv sound no picture?
It is most likely that your light engine has gone out. When this happened to mine that was the part the service technician changed.
http://www.tvserviceparts.com/WD73733.html
Aug 17, 2014 | Mitsubishi WD-73733 73" HDTV
Colors out of focus
Its convergence and both chips need to be replaced and set adjusted with the Mitsubishi remote.
Let me know what questions you have as I have repaired several hundred of these with convergence problems.
Dec 14, 2012 | Mitsubishi WS-55511 55" Rear Projection...
52 mitsubishi has small white dots of light that dont go away on most of the screen
Mitsubishi is replacing these DMD IC chips nationwide under an unannounced kind of recall for model #'s WD60C9, WD73733, WD57734, WDY657, WD73734, WD65735, WD60735, WD65C9, WD73840, WD65833, WD65733, WD73735, WD73833, WD57733, WD65734 and others. Call them @ 800-332-2119 and give them your model, serial # and date of purchase, tell them you have the white spots, they will set up a workorder with a local Mitsubishi servicer to come to your home and replace the DMD chip. Mitsubishi will supply the part (part # 276P595010) for free, but you must pay $200 in labor. BUT...if you ask for Shantell Hebert when you call Mitsubishi, and really push the issue, she will also pay half of the $200 labor fee, so you go from $400 to repair to only $100. Once that chip is replaced, the unit works great again!!
Jul 19, 2012 | Mitsubishi WD-57733 57" HDTV
How can I remove the red, green and blue color from my Mitsubishi 50 without the remote control
If colors are skewed or even look 3d some or all the time it has a convergence problem--in any case going to need the Original remote to attempt to adjust set.
GOT A MODEL NUMBER?
May 03, 2012 | Mitsubishi Televison & Video
Mitsubishi wd73733 colors have gone out, mostly purple now. there is still a picture. suspect light engine, or color wheel. how do I find out which one is the problem? TV is about 3 yrs old. it has 2 bulbs...
The Color Wheel is located inside the Optical Block. With Mitsubishi, you must replace it as one assembly. Before con dimming the Optical Block, turn the set on and press the Menu button. If the Menu looks normal, you have a problem on the chassis side. If the Menu is still purple, the Optical Block is the Problem.
I hope this helps,
Skyassoc
Feb 08, 2010 | Televison & Video
Mitsubishi wd73733 wont respond to remote control
maybe your remote have a problem,try to open your remote control and change the crystal inside it,it is an orange color parts.
Feb 18, 2009 | Mitsubishi VS-55707 TV
PROJECTION TV COLORS DISTORTED
You can try to enter the menu and go to advanced setting and adjust the convergence. Push audio to go to advanced convergence and do the multipoint convergence to re-align the colors. If this doesn't solve, you may need to do a hardware repair.. all projections of this type will need a convergence IC repair sometime during their lifetime.
Dec 07, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WT-42313 color problem
see if this helps you out
http://www.digitalhome.ca/forum/showthread.php?t=21847
Dec 03, 2007 | Mitsubishi WT-42313 42" Rear Projection...
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
