Loud squeal during wash and spin cycles, maytag atlantis washer
Machine is less than 3 years old and it is squealing loudly during the wash and spin cycles.
SQUEALING NOISE FROM BACK OF MACHINE NEAR THE END OF EACH CYCLE AND CLICKING NOISE DURING CYCLE.
  • 2 more comments
  • Anonymous Mar 13, 2014
    washing machine goes through beginning wash cycle okay. when it gets to SPIN cycle it makes a loud click and goes to EE error.
  • Anonymous Mar 22, 2014
    washing machine does not spin in spin cycle
  • Anonymous Mar 30, 2014
    when the washer goes into spin cycle the nose gets very loud during high spin speeds
  • Anonymous Mar 31, 2014
    This washing machine does not spin on any cycle. It doesmake any noises as if it were trying to engage in the spin cycle.
Maytag PAV3200 squeals during rinse and spin, but belt tension is good. What else could it be?
Posted on Oct 20, 2008
    Sniper:
  • 67 Answers
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Posted on Feb 23, 2008
2 Suggested Answers
Coldcut
  • 1554 Answers
SOURCE: loud squeal during wash and spin cycles, maytag atlantis washer
The belt is slipping and needs replaced.
Posted on Jan 26, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Maytag mav6451aww squeals loudly during spin cycle
The squeal you here is from the drain pump going out. I have replaced so many of these it's not funny. The new pumps are redesigned. All you need to do is remove the belt from the bottom, open the access panel on the rear left side (as you look at from the rear), remove the three bolts and pull the pump out. put the new one on in the reverse order. Here is the new pump.
Oct 22, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine began squealing like a bad bearing
my first thought is belts, but maybe pump
need more info for proper dianosis
Apr 24, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
During the spin cycle, the machine shakes violently and dances across the floor. It has a loud squealing noise during this. My Performa is only about 14 months old. This is very disappointing for a Maytag.
Look in owners manual. I think these washers have a 1/2 hp. variable speed motor. make sure the washer is level from front to back and side to side, if its not that could be the problem. The motor has a lot of force, the squealing could be a bad bearing not sure.
Aug 24, 2009 | Washing Machines
My washer make a loud squeal when the spin cyle is done
new brake assembly. please post your model number for further help TY
Mar 29, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Washing Machines Logo
2,133 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
