Question about Samsung DVD-VR330 VCR and DVD Recorder
SAMSUNG DVD RECORDER
MY DVD RECORDER RECORDS FROM THE TELLY TO DVD BUT WHEN I TRY TO PLAY IT ANOTHER DVD PLAYER IT DOESNT WORK IT IS JUST FILMS
  • 807 Answers
Maybe the DVD disk needs to be finalized to play in other players.
Posted on Mar 06, 2008
Anything I have recorded onto DVD from TV wont play on any other machines. It will only play on this machine I recorded on. It is the same make and model mentioned here.
If you're not using DVD+RW blanks (VERBATIM work fine), then try them. DVD-RW blanks will not play on any machine but the one that recorded the disk (according to the manual.)
Nov 24, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Why can't l play DVD's recorded on this recorder on other player
DVDs come in different versions.
Try using the -R DVDs. Once your DVD recorder finalizes the DVDs they should on any DVD palyer.
Check your manual to find out the finalizing method for your DVD recorder.
I hope this solution is helpful. Let me know.
Feb 11, 2009 | Samsung DVD-HR735 DVD Recorder/HDD...
Samsung DVD recorder will play but not record blank discs
Had mine into the repair shop. Junk it, processor is toast. Not worth the money to fix. The guy said he wouldn't even touch it.
Jan 19, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
DVDs recorded on HR720 do not play on any other player or PC!
not sure if this will solve your issue. But in order to be able to see the DVD recorded on the HR720 (or typically any other DVD recorder) you need to "lock" it. This is done in the File Manager Menu. The DVD recorder will ask you twice, whether you want to "lock" the disk. Once you have done that it will format the DVD like a normal DVD-Video, meaning it can be played on any regular DVD player. However, once locked you cannot re-open the DVD.
Hope this helps. Otherwise check in the user manual under "recording a DVD" - it is mentioned also there.
Jul 22, 2008 | Samsung DVD-HR720 DVD Recorder
Record from VHS to DVD
i should imagine so if they are not copy protected films i.e shop ones .if they are tv films on tapes etc then it would be possible to do so.
via insert the vhs tape and insert the blank dvd in to its tray
play the vhs tape and press rec to record on to dvd .
although the manual might give a better guide to doing this .
Online User Manual and Guide for Samsung DVD-V4600 DVD Player / VCR Combo by FixYa, Page #1
riz.
Mar 26, 2008 | Samsung DVD-V4600 DVD Player/VCR
My dvd player will not play HD-DVDs it is an HD DVD player
This dvd player doesnt' play HD DVD's it has a HDD which is short for Hard Drive. Which means you can use it like a DVR (Digital Video Recorder) to record your favorite shows and things like that.
Does this answer your question? If not i'm not sure what you're trying to ask could you be a little more elaborate?
Jan 25, 2008 | Samsung DVD-HR735 DVD Recorder/HDD...
SAMSUNG HR733 DVD RECORDER WILL NOT PLAY ANY REGION DISCS AT ALL
On page 45 of the user manual it says this:
Both the HDD & DVD RECORDER and the discs are coded
by region. These regional codes must match in order for the
disc to play. If the codes do not match, the disc will not play.
The Region Number for this HDD & DVD RECORDER is
described on the rear panel of the HDD & DVD RECORDER
If you changed the region codes on your player it will not work. They should be set back to 1 or whatever your model says on the back of the unit.
If this unit was purchased outside the United States, it may not work in the United States.
Here is a copy of the manual if you need it:
http://downloadcenter.samsung.com/content/UM/200506/20050618115856781_HR720-00758C-XAC-Eng_0519.pdf
Dec 08, 2007 | Samsung DVD-HR720 DVD Recorder
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Samsung DVD recorder, dvd-r121, In south africa
some avi's are in native format. make sure the avi file that you are trying to play is in divx, mpeg 4 format.
Jun 03, 2007 | Samsung DVDR120 DVD Recorder
Samsung DVD-VR330 VCR and DVD Recorder Logo
105 people viewed this question
Jerry Greenberg
Jerry Greenberg
