Question about Mitsubishi VS-60719 60" Rear Projection Television
Scrolling picture on an old big screen
I have a vs-6701 mitsubishi big screen. it has been working great for years but all the sudden, the picture just started scrolling up. it does it on all inputs. i have tried to ask local tv repair places but they just want to charge me instead of just letting me know what to do.
  • heffe Mar 01, 2008
    ya i think i have found what you are talking about. patch a wire between the c7001 and that small black thing at the bottom. i am going to do it tonight. if that doesnt sound right just let me know, please.
  • heffe Mar 08, 2008
    about that other procedure. i am going to want that one. i tried the wire and it didnt work. still rollin. so when you have some time i would be most thankfull if you would send that my way. and thank you for bein so helpful. it is hard to get anyone to help with this sort of thing.
Alright i will try it. it will take a few days. but thank you very much and i will let you know. thank you again.
Posted on Mar 09, 2008
Oh yeah. the more options i have the better. im not that good at soldering things. so l love to get the procedure. that would be wonderful.
Posted on Mar 01, 2008
  • Mitsubishi Master
  • 8,617 Answers
These models have been known to have faulty capacitors on the PIP module as a result thy loose vertical synvh and the picure will roll. The PIP module is no longer available. But if you would like I can post a way for you to bypass the module and if the modle is at fault your tv will work fine, but you wont have PIP anylonger
Posted on Feb 23, 2008
  • Sonny Berry
    Sonny Berry Mar 01, 2008
    Thats one way but if that doesnt work I have a way to bypass the pip module all together by removing it completely and injecting two .47uf @ 35V capacitors. If you need the proceedure, let me know.
  • Sonny Berry
    Sonny Berry Mar 08, 2008
    There is a quick test you can do to determine if the problem is in your PIP module, using two 4.7uf/50v electrolytic capacitors. The PIP module plugs into two connectors on the main board. Remove the PIP module, and on connector VP on the main board (the 11 pin connector), use one cap to jumper from pin 7 to 9 (negative lead on pin 9); and use the other cap to jumper from pin 5 to 11 (negative lead on pin 11). If the PIP module is bad, you will now have video. .Just solder a short piece of wire to each lead on the capacitor before starting this will prevent the leads shorting as they cross over each other. If this proceedure doesnt correct your problem it is reversible, then you will need to troubleshoot the vertical sync circuits. Let me know how you make out or if you need anything further.
Mitsubishi vs 5052 has no picture
There seems to be a lot of people having problems with this TV. My TV is doing it too. If you find out the answer, can you email me please? griff378@msu.edu
Thanks!!!
Oct 17, 2009 | Televison & Video
Mitsubishi VS-50707 screen is jittery when it first turns on
Sounds like the verticle circuit is failing a honest shop will take of this for you around 180-230 if you want to do yourself youll need a iron and some filters and an verticle ic
Sep 26, 2009 | Mitsubishi VS-50707 50" Rear Projection...
TV works fine for a while, then the picture disappears.
I would just replace the TV, the parts are not going to be made to repair this. The set is just to old.
May 12, 2017 | Mitsubishi VS-5077/78 TV
No Picture On Screen
it sounds to me like your tube has gone , go to your local tv repair shop and order a new tube its quite cheap to do so and they should be able to get it you quite fast.
Mar 10, 2009 | Mitsubishi VS-60601 60" Rear Projection...
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Only Picture in Picture Works...????
Its possible some of the surface mount capactors has failed on the pip board is so the unit will need to be replace or repaired.
Mar 18, 2007 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi VS-60719 60" Rear Projection Television Logo
107 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
