Question about Toshiba 32A43 32" TV
Very dark picture
The picture is so dark it is almost impossible to watch anymore, even though the brightness adjustment is turned all the way up!
  • 135 Answers
Hi there!
Depending on the age of the TV, it might be power supply related. Check Mains smoothing cap or others in the area. Video circuit is also a possibility. Tube would be the last option to look into depending on the age of the set, Good luck,JUS004
Posted on Feb 29, 2008
Screen is really bright on dynex dx-l42-10a. Still show picture but bright no matter how it is adjusted. Was fine while watch TV & picture just got bright like the darkness quite. Any suggestions & what...
Sounds like screen voltage has exceeded much. Its LOT adjustments should be checked. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Aug 25, 2014 | Televison & Video
Dark picture even after new lamp was installed
Reseat all connectors that you removed then try once more. its a back light problem reseat back light once more.
Oct 15, 2012 | Hitachi 50VG825 50 in. LCD HDTV
My youtube viteos are too dark! How can I make what I am viewing brighter and clearer?
It's impossible that JUST youtube videos you are watching are too dark.
You'll have to adjust the brightness settings on your monitor.
Mar 07, 2011 | YouTube Videos
Jvc 27'' TV is too dark
There are two small holes on the rear side through which you can adjust focus and screen. Use a flash light and locate the two adjustable slots inside the holes. This part carries high voltage. Do not use a metal screwdriver to adjust. Put the TV facing a mirror so you can see how it works. Do not turn more than 1/8th of a turn. The focus control makes picture sharp or fuzzy. Screen control could change brightness. While watching the picture in the mirror, slightly adjust the screen control. Do not turn too much. If it doesn't work, then call a JVC authorized repair center.
Jan 22, 2010 | JVC AV-27D203 27" TV
Make sure there is no light shining on the electric eye it will adjust brightness automatically also check bulb for dust and dirt
Nov 30, 2009 | GPS
My 61" hitachi rear proj has a very dark picture.
It sounds that lamp in TV is weak and not throwing enough light to bright the screen for good image.
How old is this TV and did you replaced its Lamp recently?
If lamp has not been replaced yet or in last 2-3 years, replace it.
Oct 13, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Poor Picture Quality
Todd, In the user menue there has got to be adjustments for the brightness, contrast, sharpness,etc. I know there is no such thing as a simple tv anymore. On some sets if you do not have a remote control, you cannot make any adjustments. If you have one for this set and it works, trust me, the settings are in the on screen menue.
Hope this helps,
Jun 18, 2009 | RCA L23W10 23 in. LCD Television
Screen is too dark
with a flashlight at the back of the set often times there is an adjustment you can make WITHOUT having to open the set!!!
look for a little hole in the back of the plastic cabinet labeled SCREEN then with a flat screwdriver holding only the plastic handle, insert it into the hole and SLOWLY rotate until the screen brightens up until it is watchable.
This is compensating for age in the picture tube. you may get a few day or a few more years! of a much better picture.
If you start seeing some thin lines on the screen then back off you have gone too far. Do this adjustment with the brightness and contrast controls on the menu turned up all the way.
it is also safe to play with the focus adjustment right next to the screen if thing seem a little blurry. you will need two people one to watch from a distance for best picture.
Feb 10, 2009 | GE 31GT660 TV
Dark scenes are impossible to see
This is a fundamental limit of Ti DLP. The part can not reproduce low grey scale, so low light film is dominated by artifacts. It helps to sit farther away from the screen. The color shift is caused by a factory tollerance on the color wheel, but there is no user adjustment for it.
Sep 10, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Dark picture
Your problem could be the secondary anode cable or CRT socket, and you cannot fix this problem yourself unless you are a techie. It happens when your CRT base socket burns out, or when the pins are rusted or when the spark gap conducts to drain out the secondary anode voltage to the ground. It is better you call a service engineer.
Dec 15, 2007 | JVC AV-27230 27" TV
Toshiba 32A43 32" TV Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
