Question about Indesit WA 125 Front Load Washer
Indesit omegar 1100
The machine fills up with water but then the dail dosnt move but i can hear it clicking
  • leedav66 Feb 24, 2008
    thank for your re the dail as not come loose i put the machine on it fills with water the dail dosnt move there is a churning nose but even when you move th dail on by hand the drum will not move round. all it will do is fill and empty. the drum will move freely by hand.
  • leedav66 Mar 02, 2008
    thanks for your help yalmer sorted it out last week beleve it or not it was carbon on the motor.
  • 552 Answers
Check inside to see if the dial has come loose from the timer.
If it is clicking then the dial is not turning with the timer.
Let me know what you see.
Posted on Feb 23, 2008
  • Hjalmer Lamminen
    Hjalmer Lamminen Feb 25, 2008
    Please look at www.howstuffworks.com
    You may have a gearbox problem.
    Check for oil under the machine.
    If there is your gearbox is leaking.
My Indesit washer model no IWC61651 ECO fills with water but does not do the wash cycle will run for hrs keep filling water but programme never moving
Lynne,
The drain hose for the washing machine is pushed too far down the standpipe causing the water to siphon out of the machine. Look at the diagram below:
-make sure standpipe is at least 18-30inches high
-only push drain hose in 4-6inches
Aug 16, 2016 | Indesit Washing Machines
Washing machine makes clicking noise after filling up and wont spin. Kepps on clicking until i force shutdown, which then drains the water away.
hi, the problem you have is the motor carbons (brushes) have worn down ( which is natural if machine is used every day ). the machine fills up with water but there is no motor action. the clicking noise you are hearing is the relay on the pcb sending a signal to the motor to turn, but with the carbons worn, there is no motor action. Easy enough to replace them. UNPLUG machine before any repairs are carried out.
Dec 19, 2013 | Indesit Washing Machines
Indesit wil103 guides
Reset the machine by unplugging and see if that will help.
Oct 15, 2013 | Indesit W 123 Front Load Washer
What controls the water cut-off feed during cycles and when dail is set in off position.
There are electronically turned on and shut off water valves that are controlled by a water level sensor which varies based on what load size/water level you need Small, Medium, or Large. So if the valve gets stuck open since it's an old machine, the water will just keep coming in. But let me ask you this? If you turn the house water value on n NOW...will the wash machine just start filling? If so, it means your valve is stuck open so you would need to replace the water valve which is like $50 online. If the house water valve is on, and when you start the washing machine it starts filling, but just keeps on filling...that's probably because your water level sensor is messed up. So you have 2 things to check...is it the washer water valve is stuck open? or is it the water level sensor that isn't sensing when the washer is full so it just keeps filling it.
Dec 21, 2017 | Home
The water won't shut off keeps filling the tub
seems like a water valve is suspect, turn the water off st the taps, if it stops filling up thats your problem, if it dosnt and the drain is beneath the sink, its possibl the dirty water from the sink is going into the machine, make sure the pipe is higher than the botom of the sink bowl.
Apr 07, 2010 | Washing Machines
Indesit WIXL85 water level
On a normal wash cycle, you will see very little if any water sloshing around, this is quite normal on todays washers.
You shuold see a lot more on the rinse cycle, as it is a higher fill.
It is usual to more less fill the compartment with powder, unless you are only washing a few items, then half fill it.
Hope this helps.
Dec 19, 2009 | Indesit W 123 Front Load Washer
Indesit WA 125 Front Load Washer Logo
114 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
