Question about Kitchen Ranges
The Bay Beaumark self-cleaning range - 30 inch Convection stove - 12891-2 Model
Timer seems to be off but the oven starts repeatedly for short periods then switches off.
5 Suggested Answers
jessee007
  • 310 Answers
SOURCE: After self cleaning, Range trips circuit breaker when using convection
self cleaning ovens use super hot seting to bake the oven clean and it sounds like it melted a wire and it is shorting out the oven on that setting. look at the wires you can see or easy to remove panels
Posted on Jan 01, 2008
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
  • 857 Answers
SOURCE: GE oven door won't unlock
Not usually, there may be a problem in the locking mechanism. You must check it out and get that fixed.
Posted on Jul 20, 2010
blueextc3221
  • 15935 Answers
SOURCE: display panel on stove not working properly, cannot use the oven
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
&^%$tr
Posted on Oct 01, 2010
I have a GE self cleaning oven I want to clean. Do I need to take racks out, and am I able to use stove during this process
If you do not take the racks out they will discolor and not slide in and out as well as before. Do not use the stove for any other purpose during the cleaning process. Oven temperatures reach over 900 degrees during cleaning. Open a window to vent out the fumes from cleaning.
Oct 18, 2015 | GE 30" Self-Cleaning Freestanding Electric...
Have error message on my ne fiigidaire gallery gas range...error Sd...oven will not work and timer etc will not function properly
Some stoves have an override on the oven side... oven pilot light must be lit or it will go to safe mode. if it is an auto light then check the fuse usually located up by the top left side on bk of stove.
Jan 02, 2015 | Frigidaire Gallery 30" Self-Cleaning...
Elextrolux Range stuck in Demo Mode
Phone agents and ask for workshops. Quote them the model and problem you have.
Jun 06, 2010 | Electrolux 30" Self-Cleaning Slide-In...
Hi, My LG Dual Convection oven is taking over one
mine too. it took 2 hrs to get to 300. Self cleaning does not get hot enough to clean. it seemed to work for a day after that, but is not working again. i got the error F-7 but can't locate my book to see what that means. the stove is only 1 year old....have you found an answer to your problem??
Nov 26, 2009 | LG 30 in Kitchen Series Dual Convection...
GE 30" Self-Cleaning oven
I do not think that the problem is caused by the broil element, but I cannot rule that out. I believe there is a short or an open in the circuitboard. Unless you find the short or open you will need to replace the entire control board.
Jul 30, 2008 | GE 30" Self-Cleaning Freestanding Electric...
Kitchen Ranges Logo
451 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
