Question about RCA P46810LV 46" Rear Projection Television
Won't turn on and has a arcing noise
Won't come on and has a arcing noise as it tries to.
  • 61 Answers
Block is bad,part number is 205064,sounds like a hole has burned in the part,its in front of the tv behind the speaker grill,snap off the grill and there is a panel,remove the panel and between the left tube and middle tube is the part it has red wires on it
Posted on Apr 01, 2008
What is the buzzing noise coming from the back of the tv when turned on one for minute or two then stops, and over and overf
Does the sound seem to be coming from the right rear of the set? It could be the inverter board is arcing when trying to turn on the backlights, likely a bad solder connection on one of the transformers (a very common problem) This would sound like a buzzing, or a arcing sound. If it is coming from the speakers it could be a power supply problem.
Sep 11, 2009 | Panasonic Televison & Video
My RCA projection tv makes a loud buzzing, humming noise. Does as soon as turned on even before picture comes on, does not stop till tv is turned off.
buzzing noise is cause by small electrical arc inside the unit or a problem in your audio circuit.if you can open the unit up and check if its an electrical arc.
Jun 21, 2009 | RCA HD52W59 HDTV Projection Television
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Mitsubishi VS-50707
Check the CRT socket of the tube that is arching. Could be a solder connection or shorted CRT. If you need further assistance let me know.
Feb 03, 2008 | Mitsubishi VS-50707 50" Rear Projection...
T.v. not coming on ,turned off by itself with an arc noise
The part is known as a flyback transformer.. it will have to be replaced.. also the horizontal ouput transistor will possible most likely be bad..
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
No video, No sound, TV pops when you turn it on!?
you have high voltage arcing taking place ,poss tubes or flyback,splitter assy,focus block, you must try to pin point where or by what the arcing is taking place,safety first. unplug the unit and inspect for black burn spots on or near metal parts.
Oct 07, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
127 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
