Question about Trendware TEW-452BRP Wireless Router (TEW452BRP)
TEW-452BRP - can't open a port (forward)
I tried to fix this problem for over 20 hours now and I'm starting to give up.
What i'm trying to do is forward port 60065 for uTorrent client to my static ip: 192.168.1.200
the dhcp range on the router is: 192.168.1.100-199
i added 60065 to virtual network to my ip (.200)
added tcp and udp 60065 to routers firewall rules
i added utorrent, tcp, udp to windows firewall exceptions
i turned off windows firewall
i tried grc.com's shields up and it shows that the port is "stealth".
i tried portdetective.com and it shows the port is in use
the uTorrent client shows that there is no incoming connections....
any help would be greatly appreciated,
thank you,
Patrick
I had the same problem.. the router did forward another port for me (port 12345) so i just set the port for uTorrent to 12344 and it magically worked... i'm not sure why but i would try setting the port to a lower range
Posted on May 02, 2008
Wireless netoworking (router)
Go to start-> run-> devmgmt.msc
In the device management right click the cdrom and click scan for hardware changes
Apr 29, 2010 | Trendware TRENDnet TEW-452BRP 108Mbps...
Wan and All LAN led bulbs are continuously on- Router not working
Straighten a Norwegian paper-clip, and insert one end into the small hole in the back of the router, to "reset" the router to its "factory" settings.
Or, spend $50, and replace the router.
Mar 26, 2010 | Trendware TEW-452BRP Wireless Router...
I am unable to connect to internet with laptop
you did not tell us how you connected to the internet by wireless or ethernet cables. but any way first check the setup of your modem router otherwise your network provider.
Oct 05, 2009 | Trendware TRENDnet TEW-452BRP 108Mbps...
I have to disconnect and reconnect my TEW-432BRP router
Hi! please try to download the firmware of your router the routers website and upgrade the routers firmware.possible is. the firmware is corrupted..
Jul 18, 2009 | Trendware TEW-452BRP Wireless Router...
Slow internet connection
Sometimes ISPs (Internet Service Providers) upgrade information on their end to improve or alter something about their network. When this happens, routers have outdated information from the modem. You might want to try power cycling the modem and router. To do this, unplug the power from both the router and modem. After about 15-30 seconds, plug the modem back in. Wait for all of the lights to come on excluding the "PC Activity" light if it exists. Once the modem is registered with your ISP, plug your router back in and test your net speed using a site such as:
http://www.speedtest.net
If your service is back to normal, then you're all set. If it isn't, you may want to contact your ISP as there could be something wrong with the route traffic is taking from the node to your residence.
Mar 05, 2009 | Trendware TRENDnet TEW-452BRP 108Mbps...
Ginko
You must download the firmware first from the manufacturer's website.
Oct 31, 2008 | Trendware TEW-452BRP Wireless Router...
Slow outgoing internet
I would suggest checking in the router's admin panel. (Typical accessed by typing 192.168.1.1 or 192.168.0.1 into your address bar on your web browser. Type your password (if you do not know it check your owners manual for the default) and check to see if you have any firewall or port restrictions set.
Feb 21, 2008 | Trendware TEW-452BRP Wireless Router...
Low outgoing internet
If you are experiencing slow speed while connected to a router, there are a number of things that can cause that problem.
If its the router causing the problem it could be a bad router, or a setting on the router.
1.) first thing i would do is a traceroute to google.com so from a command prompt type tracert google.com and see if your few hops are high. if they are when the router is connected but not high when the router is disconnected, then we know its something with the router.
log into the router's configuration.
2.) on some models you can change the MTU size.
3.) make sure your not filtering any ports that you need such as 110, 25
start with those 3 steps and let me know how that goes.
Feb 20, 2008 | Trendware TEW-452BRP Wireless Router...
I can't get a connection
Try this WII setup guide:
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Feb 01, 2008 | Trendware TEW-452BRP Wireless Router...
I lost the installer....
yes if you are formating you will need to re install the driver.
you may find the driver for free at.
Trendware.com
downloads
or you may type in google Trendware TEW-452BRP driver download.
Dec 06, 2007 | Trendware TEW-452BRP Wireless Router...
Trendware TEW-452BRP Wireless Router (TEW452BRP) Logo
631 people viewed this question
Top Trendware Computers & Internet Experts
Michael Galve
Michael Galve
Prashant M
Prashant M
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
