Question about Philips 55PP9401 55" Rear Projection Television
55PP9401 Phillips I have noticed that my pitcure is like looking at a 3-D video with out the glassed. All the colors are not together! I have used the Intele button to realign the colors about that will not work any suggestions?
  • 1 more comment
  • Anonymous Apr 24, 2008
    Colors run together in waves across the screen
  • jwelker03 May 06, 2008
    Same with mine, but i have like a yellow curtain at the top of my screen.
  • Anonymous Jun 22, 2008
    any suggestions?
We have the same tv and have spent almost 2,000. on repairs for the same problem = 3 times in less than 6 years!!
Posted on Feb 24, 2008
Phillips 42 glass base exploded at 4:00 am.... no apparent reason
Same thing happed to us. We had the TV on the wall for well over a year and had the base buried in the closet in the same room. About 8:30PM late last year we hear a muffled bang (pretty loud as we were in the same room). Looked in the closet and there where hundreds if not thousands of glass shards everywhere. So far, I've noticed 5 incidents of this happening and 3/5 are Phiplips bases. There's a video on YouTube of a Samsung base that exploded too...very disturbing! Only thing I can think of is that they use some kind of a polymer mix with the glass that's unstable.
Mar 05, 2012 | Philips 42PFL3603D/27 42 in. LCD TV
When the screen is dark there are lines that run back and forth across the screen which is only noticable when pitcure is dark immage.
the screen bias needs to be turned down-ehind the front cover which is behind the grille there is a small black square about 3 inch square 6 little knobs sticking out 3 say in small letters screen and 3 say focus, don't adjust the focus just the screen for the coresponding color that shows up when picture is dark.best way to do this is darken the room and put it on video input with no signal if lines are white slowly
adjust 1 color after the other counterclockwise untill
lines disappear if only 1 color shows then only adjust the knob with the matching color. this is a very fine adjustment, to much will make your auto focus stop working. check it after you are done
Jun 20, 2010 | Sony KP-51HW40 51" Rear Projection...
My phillips 55pp9401 looks orange and purple , heres a picture of what it looks like, i tried the intellisense and it does nothing. http://palmsprings.craigslist.org/ele/1679632114.html
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Philips 55PP9401 55" Rear Projection...
Phillips convergence proplem . red arrow will not align. bowed picture at bottom and double lettering everywhere
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Aug 05, 2009 | Philips 55PP9401 55" Rear Projection...
My TV looks like if i was watghing a 3D Movie.
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jan 26, 2009 | Philips 55PP9401 55" Rear Projection...
Philips 55PP940 Screen blurry
the convergence ic will be hot what u need to do is send me a pitcure of the problem to dkreavis@yahoo.com and i will be able to hp u
May 29, 2008 | Philips 55PP9401 55" Rear Projection...
Three colors are not together
Convergence problem needs two ic 's to fix.
May 25, 2008 | Philips 55PP9401 55" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
How doi adjust convegence manually on phillips 55pp9401
Order service manual from partstore.com ..........
procedure is complicated..............T.
Dec 08, 2007 | Philips 55PP9401 55" Rear Projection...
Phillips 55PP9401 Convergence Problem
STK392-110 convergence IC's upgrade to STK394-160.....
I use Hitachi brand part # CZ 01341 ... change both.......
Check for dis-colored resistor (s) = replace with exact value...
Please respond............T.
Aug 12, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
