Question about Zyxel P660HW-D1 Router
P660HW DSl problem
When I connect my new P660HW Router, I can't get the DSL LED to remain solid and therfore get an internet connection. The DLS LED on my old box which is a Zyxel prestige 600 series works fine, so its not a connection problem. I even brought the Router back to the store because I thought it might be faulty and had it replaced with a new one. Its exactly the same. Can anyone help. Could it have anything to do with my Kaspersky anti-virus software?
  • 3 more comments
  • Cruyff14 Feb 23, 2008
    The DSL light doesn't remain constant, it flickers. I bought this Router so that I could keep the internet on my PC but also pick it up on my laptop. The model is Zyxel Wireless ADSL Modem Router P660HW and G202
    The DSL Light stays on for a couple of seconds, then flashes twice, then remains on for a couple of seconds before flashing again and so on. My service provider says that unless the light remains on constantly, I cant get an internet connection.
  • WillieJoe89 Mar 18, 2008
    I have exactly the same problem as Cruyff14. The ZyXel P660 HW + G202. The wireless network Connection status alternates between Speed 54Mbps Signal Strength Excellent Status Acquiring network address to .... Not Connected. I have a wired broadband connection (different router) it was (and is) working fine but I wanted to change to a wireless connection in order to set up a home wireless network. I have un installed and reinstalled the software at least 6 times taking care to input the correct wireless key etc. WillieJoe89
  • regfo Nov 26, 2008
    guys ftomISP step in with d-link router and show me that everything works ok (with teir router). but my zyxel does not work! have the very same problem
  • nikgandhi Dec 27, 2008
    same
    Brigadier General:
  • 3,614 Answers
What do you mean to "remain solid"?
What model of your router and your ethernet adapter model?
Do you use wireless networking?
Posted on Feb 23, 2008
  • micromaster
    micromaster Feb 23, 2008
    you mean Flickers or flashing LED?
    If it's flashing it means that you got connected to the router and bc you were either uploading or downloading data through that router.
  • micromaster
    have you try for a soft reset on your router?
Diagnostic light keeps blinking
Check the LED lights that are blinking on the front of the DSL modem. Check the "Internet/Online" LED and make sure it is blinking green or a solid green. If this LED is not blinking, then the modem is not getting a phone signal, or the service is out. Remove the line and check it to make sure that you're getting a signal.
Check to see if filters are connected to the phone lines that are all around the house. These filters separate the phone line from the DSL line so that the lines do not crosswire and disturb the Internet connection or the phone connection. The DSL is usually shipped with a couple of phone filters. These phone filters can be purchased at many electronics stores or provided free from your Internet Service Provider.Check to see if the modem is connected to a wireless router. If the modem is connected to the router, try disconnecting the router and connect the modem straight to a computer. If the modem is also a multi-port wireless router, then connect the computer to a different port on that same router.Reset the router if the previous steps do not resolve the problem. Follow the initial set up instructions given to you when you first installed the router. Perform any firmware updates that might be needed once online, and use the discs that came with the modem.
Feb 07, 2012 | Cisco RVL200 Router
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
I have a Zyxel Q1000z dsl router power light and DSL light on solid green however internet light is completely out not red or green or anything Qwest my service provider tested the line as good. I have...
If you have called your service provider and they have confirmed that the connection is good then there may be a problem with:
A- The router itself
B-The physical connection from the ISP's last access point to your router.
Your best bet would be to (if you haven't already) reset the router and wait AT LEAST 10-15 seconds before plugging it back in.
Another solution would be to go to the router configuration page and check the router logs to see when the problem first occurred, and what could be causing it.
Jul 09, 2011 | Zyxel P660HW-D1 Router
My dlink dsl-2540u router not connect to the internet. Dsl led blinking & sometimes totaly off.
Contact your ISP immediately- the issue you have is called no sync. Basically with the DSL led going completely off- that would point to a bad modem, however the fact that you have no sync otherwise indicates your DSL provider may need to service your DSL line.
Jul 09, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I tried to change my security to wep and it just stopped connecting so i reset the router and now there is no dsl wlan or internet light on just a power light
Let's guess. This is a DSL connection and you just reset the access to your internet account.
Find the paper or person who set the system up originally and start all over. Next time, have some sort of idea what you're doing BEFORE you press the reset button. You started with access to the router, and changing Wireless Security settings could have been undone if you went back into the box from a WIRED connection and turned off or altered the WEP code.
Good luck.
Carl
May 25, 2010 | Zyxel P660HW-D1 Router
When I connect the DSL modem and the D-link router together and I have my main computer hooked up to the number 1slot then I power them on I see that the DLS modem connect to the internet I have all green...
Connect the DSL modem to the WAN port of the D-Link. It should be labelled or colored differently. You then connect your computer to ANY other jack on the D-Link.
Apr 29, 2010 | D-Link Computers & Internet
Setup of d link dsl-2740b on my computer
the dsl connection is your broadband signal. check the router box. if the dsl light is off or flashing on the front, the setup will not work. this light needs to be solid. remove all devices from telephone sockets in your house, connect just one filter and your new router to it. check the dsl signal, if the light is solid green. the problem is with the physical setup in your house. If the dsl light still flashes contact your isp or broadband supplier.
Apr 15, 2010 | Computers & Internet
DSL status LED is not on. After an ISP problem the DSL status LED is not on. ISP told us to power off the router for ten minutes. After re-powering the router DSL status LED is not on.
Two problems,
1 - The power adaptor of the DSL Router is not working,
2 - the Telephone cable is not connected properly
3 - If it's a cable modem then the cable is not connected properly
4 - Check with you service provider if he's made changes in the exchange and if you need a new DSL router.
Your DSL service provider should be able to solve this issue.
Dec 06, 2009 | Computers & Internet
No Internet Connection
what type of internet connection are you using? DSL or CABLE? BPCS
Jan 13, 2008 | Zyxel P660HW-D1 Router
ZyXEL adsl wirless modem router P660HW
To bring up the blue screen you need to open internet explorer (or whatever) and type the ip address given. In my book it says 192.168.1.1 after that you should get the blue screen. You can set up the connection then.
Jan 08, 2008 | Zyxel P660HW-D1 Router
Zyxel P660HW-D1 Router Logo
374 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
