Question about HP Pavilion dv6000z Notebook
Medion MIM2120 Laptop
Hi
I need to swap the memory in a Medion MIM2120 laptop. Is it under the keyboard? If so how do I get the keyboard off, without breaking it!
Thanks for your help in advance
  • 2 more comments
  • BobTheBrit Feb 23, 2008
    Thanks Mike!
    When the memory arrives from cucial, I'll give it a go!
    Best Regards
    BobTheBrit
  • BobTheBrit Mar 15, 2008
    Yup, I found that out. I have fitted 2gb to the users laptop and it is now puring like a kitten
    Thatns unfixed
  • j mottram Nov 16, 2008
    HI I NEED TO FIT A NEW POWER PLUG TO MY MEDION MIM2120 LAP TOP, WHAT DO I NEED TO TAKE OFF TO DO THIS ?
    J J MOTTRAM
  • Anonymous Jan 13, 2009
    Hi,I have a problem with the DC socket that is within the computer.moving the power plug causes the charging to stop.I replaced the plug from the charger thinking that was the cause but it didn't resolve the fault.Anyone any ideas on how to get to this connector? If I remove the bottom somehow will this give me access to the socket?GGW.
Remove the large panel (7 screws) on the base of the machine.
The memory is situated under a black flexible plastic cover about 75 x 30 mm - amost directly below the earphone and mousepad area.
Memory is held in position by clips at each side - press them outwards and memory card will pop-up.
A second card can be fitted below and slightly higher than the first.
I have just fitted IGb and will probably put in another (max 2GB), - cost about £15.
Hope this is of use.
Posted on Mar 15, 2008
    Problem Solver:
  • 11 Answers
Hi Friends,
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
Posted on Oct 08, 2010
MY MEDION MIM2120 LAPTOP KEYBOARD SUDDENLY STOP TO WORK WAT CAN I DO TO MAKE IT WORK AGAIN
Posted on Aug 18, 2008
    Genius:
  • 1,019 Answers
Hi Bob,
this is a job if your confident and competant with pcs or computing in general.
medions are a work of art, in themselves.
you are correct in thinking the memory, is under the keyboard. you should have 2x ramslots located towards the centre of the laptop.
first remove the battery, as you want no-power in the machine at all, due to electrostatic discharge, which will damage the memory, and or mainboard.
Look carefully at the power panel, this needs to be removed before accessing the keyboard area. check the rear of the laptop, to see if there any screws mounted, at the top of the laptop base ( under screen Height ) if not. you carefully prise the control panel upwards, over the keyboard. take care not to damage any keys. i,d suggest work from centre outwards. until the power switch panel pops up out of it,s location. be careful not to lift too high, these are usually ribbon cable connected, but have enough room, to flip towards the screen.
you should then find 1 or 2 screws securing the keyboard.
same again ribbon cable connector. the keyboard should remove by sliding towards screen. tags into mousepad area.
replacement is in reverse sequence.
any problems, please ask.
Mike @ Compurepair.
Posted on Feb 23, 2008
Red light flahes even when power adaptor is connented
Most likely this is due to a faulty battery. This indicates that the battery is unable to hold a charge despite being plugged in with the power adapter.
Feb 28, 2011 | Medion MIM2120 COMPATIBLE LAPTOP LCD...
Hi i have a medion MIM2120 laptop and when i turn it on all i get is the screen saying press f2 to enter system set up. But if i press f2 nothing happens i have changed the keyboard and used a usb keyboard...
it could be ur hardrive. mite have missing file that are vital to te computers opperating system. insert a rercovery disk (asuming u have one) and repair the opperating system
Nov 05, 2009 | Computers & Internet
How do I fit wireless card into medion mim2120 laptop?
I assume you mean "wi-fi" wireless access. The easy solution if wireless networking wasn't built in is to use a USB wireless adapter that simply plugs in to any USB connector on the laptop. These adaptors are available at retailers where you can buy computers as well as from many online sources. The adapter will come with any software and installation instructions you need.
Please take a moment to give this solution a fixya rating if it has been what you needed, and thanks for asking here!
Mar 05, 2009 | PIONEERPOS M55E25R30P PC Notebook
Laptop keyboard not working medion mim2120 notebook pc
this and my mouse have also stopped working, idk the problem but i fixed it once and whenever i wanted to turn it off i just put it into sleep and it worked fine when i started it up. i came to a situation where i had to restart the computer and it didnt work again and now i cant fix it.
Aug 18, 2008 | Computers & Internet
Keyboard on my Medion MD 40812 PC Notebook will not work
the keyboard needs to be check to see if it is not clip in propery or if the keyboard need to be replaced.
Aug 18, 2008 | Medion MD-40954 Notebook
Updates not installing
I have found, depending on the update, that downloading them manually to your desktop, then installing them from there usally does the trick. Just write down the KB number of the update and go to http://www.microsoft.com/downloads/Search.aspx and download.
Mar 05, 2008 | Medion MD-40954 Notebook
Medion MD41060 Memory Installation
Hey, as far as my knowledge is concerned, the battery compartment is on the backside of laptop and there is a symbol on that compartment. you just need a screw driver to open two screws and reach the RAM compartment.
Try that you will fixup your problem.
Feb 13, 2008 | Computers & Internet
DDR2 upgrade
should be easy on bootem under one of them panels in middle usally do u wann add 1 gb more
Jan 07, 2008 | Medion md40298 Notebook
press the blue button botton left of the keyboard that says Fn (function)
at the same time press F1 this will enable the laptops wireless connection, this should be shown by the light 2nd from the right
Dec 04, 2007 | Medion md40298 Notebook
HP Pavilion dv6000z Notebook Logo
853 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
