Question about Hitachi Deskstar 7K80 Hard Disk 80GB, 7200RPM, ATA-6, 2MB Cache, Desktop, 20PACK (HDS728080PLAT200A3021020PK) Hard Drive
Hard drive installation
Hi just installed a new hard drive from pc world.brown box no driver or instructions.previous hard drive was drive d. the new drive has installed as drive e but unable to access it.help please.mack.
    Champion:
  • 331 Answers
When you install a new drive; you have to initialize it, then format it for it to be useable.
Posted on Jul 23, 2010
  • 37 Answers
You need to format the drive first before you can use it. If you are using windows xp, right click on the drive E and then click on Format. You can put a check mark on the box next to quick format if you like it faster and then click on start.
Please leave me a comment after you did what I said.
Posted on Jun 03, 2009
SOURCE:
My compaq presario/sr1750nx/ w sata drive/ amd 64 athlon. came with windows XP. I put put a new hard drive in the computer, with Windows 7 installed. I power up the tower, and the monitor stays blank?
Hi!
It is very unlikely to get the machine working when the windows 7 HDD was installed in a different type of computer, because all drivers installed with the operating system are related to the hardware from the other computer.
The best solution is to make a clean install, using the windows installation disk, and after that to download from Compaq's site the latest drivers.
If you still have reasons to use that previous installation, you can try to do the following:
1. Boot from the Windows installation disk
2. Follow all steps until it discovers the previous installation on the HDD
3. Choose to repair it (or better upgrade, if this option is available).
But doing so there only 50-50 chances to get it work, or to get it to be stable.
Hope it helped.
Regards,
Aug 20, 2011 | HP Compaq Presario Media Center SR1750NX...
Restore will not work comp goes thru the motions and comes back with unable to restore, it doesn't matter how far back you go
Hi, I believe you need to reinstall your operating system, follow these instruction:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 15, 2010 | Medion MD-1768 PC Desktop
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
I have a ibm thinkpad t43 model laptop. the problem is after format the hard disk i install the audio driver (download from the web) but it can't work but earlier that driver work
I am not sure which OS you have installed, any how if you have installed XP on your notebook then us the provided URL to download and install the audio drivers:
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/1ya210ww.exe
Installation Instructions
This driver can be installed with the Software Installer, or
by following the instcructions in the next section.
In both cases, please confirm that the driver is correctly installed,
by determining the installed driver version as described below.
Clean installation:
1. Start Windows and log on with the user ID authorized as
an administrator for Windows 2000/XP.
2. Extract this package onto the hard drive.
3. Click Start, then click Run.
4. Type C:\DRIVERS\WIN\AUDIO\SETUP.EXE in the Open box and click OK.
5. Follow the instructions on the screen.
6. Click Finish and Reboot the system when prompted in order to
complete the installation.
Upgrading or reinstall:
Note: Remove any previously installed driver using the uninstall step
5. If the dialog box appears, select Reinstall or Update and then
click Next.
6. Click Finish to reboot the system and complete the installation.
Unattended installation (Windows 2000/XP):
Note: This is for system administrators' use only.
In the step 4. of the Clean Installation procedure type
C:\DRIVERS\WIN\AUDIO\SETUP.EXE -S -SMS in the Open box and click OK.
Jun 05, 2010 | Lenovo IBM ThinkPad T43 Notebook PC -...
Problem installing broadcom netxtreme gigabit NIC in windows server 2003 R2 standard, the driver doesn't load, error code 38
Determine Correct Driver Click Here
1: Uninstall any unwanted programs.... (make sure/Try to Clear your Hard Drive more than 50% as free)
2: Update virus software
3:Restart Computer IN Safe Mode
4: Run Virus Scan
5: Restart in Safe Mode
6: Uninstall Existing Driver Software From Device manager
7: Restart computer in normal mode
8: Start>Run> type %temp% and hit run.
9: Delete all files in this folder....
10:Restart Computer
11: DEFRAG
13: Restart COmp.
14:Install Driver
>Troubleshooting for Error 38
The error message for this error appears as: "Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory."
This error occurs when a previously loaded driver is preventing the new driver from loading. To fix this error follow these instructions.
  • Reboot Your PC
  • Open the Device Manager and in the device Properties box, select the General tab.
  • Properties Uninstall(Right Click Mouse) / Disable(In Property)
  • Restart PC
  • reinstall /enable
  • Once you have followed the instructions throughly, reboot your PC
Hope this make you Better Conclusion....Thanks for Using FixYa.....
Apr 21, 2010 | Computers & Internet
Not recognized
A Network Drive, that which is connected via an Ethernet cable will not appear as new hardware. You should have connected it to the router on your network, then seen it as a network device.
Check My Network Places.
You will need to Map a drive to see it every time you boot.
Nov 29, 2009 | Western Digital 500GB My Book World...
New hard drive installed..no dvd rom drivers ? can't get World of Warcraft to install
do u have a dvd rom plug in ? cause they dont usually required drivers
May 28, 2009 | Computers & Internet
Unable to install Maximym Mahjongg game. Computer cannot read the disk.
Good morning! please try to check from the Device Manager if your CD drive is enabled & working properly, if not we have to reinstall the driver, then after reinstalling the driver if still it doesn't read the inserted CD, then try to install a new CD Drive unit -if it works then the previous CD drive unit is defective. best regards
May 07, 2009 | Computers & Internet
Ethernet controllers for dell dimension 4600
You can download the driver you need from Dell here. The page also gives you installation instructions if you run into troubles.
Please give this solution a good rating if it's been what you needed (fixya's are nice!). Thanks for asking here!
Feb 27, 2009 | Dell Dimension 4600 PC Desktop
Computers & Internet Logo
234 people viewed this question
Top Hitachi Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
