Question about Maytag 24 in. DWU7402 Built-in Dishwasher
Rinse cycle when temp is on and fan is on heat the rinse cycle does not work because water drains out of tub
  • 105 Answers
Is the drain from the dishwasher in a syphon or runs into a free drain that air can break siphon cycle
or is drain up high enough eg 600 off floor be fore going into drain if not water will run in then straight out
Posted on Feb 24, 2008
My dishwasher has power to it but the heat dry option is lit and it wont start ant idea what to do?
Hello
Do you have any of the extra functions selected, such as "Hi Temp Rinse" etc?
The selector switch has a selection for Hi-Temp Wash; the switch is in parallel with a thermostat mounted on the bottom of the tub and with a contact in the timer. The
selector switch, temp assure thermostat, and the temp boost thermostat are all in series with the timer motor. Both thermostats are normally open thermostats. When
the timer reaches the end of the second wash cycle, the contact in the timer supplying power to run the timer motor will open. At which time, if the selector switch for the Hi-Temp Wash has been selected, power to run the timer motor must come through the thermostats. The temperature of the water in the tub must rise to 137° ±5° F for the thermostat to close and the timer motor to advance. If the water temperature is below 137° ± 5° F, the timer will pause until the heating element raises the temperature of the water in the tub and allow the thermostat to close.
Hi-Temp Rinse
If the selector switch was a selection for a Hi-Temp rinse, the switch is in parallel with a thermostat mounted in the tub, and the contact in the timer, the same as the Hi-Temp wash. The operation for the Hi-Temp rinse will be the same as for the Hi-Temp wash with the exception, on some models, the temperature of the water in the tub will be 150° ± 5° F for the thermostat to close to give a sanitizing rinse.
What do we learn from this? That you either have a bad heater or a bad thermostat. Check the heater for continuity with our OHM meter.
Aug 03, 2011 | Frigidaire Dishwashers
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Fills to wash, drains but then tub won't fill for rinse cycle;
u need a new cold water valve, if u check the temp of the water while its filling it is mainly hot, or u have the hot nd cold hoses on the wrong way , as all rinses r cold
Jan 31, 2010 | Fisher and Paykel GWL11 Top Load Washer
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
Aug 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
No water enters on rinse cycle
I was partially wrong on my diagnosis. No cold water enters on either the wash or the rinse cycles. I also heard odd noises from the inlet valves. I realized the cold water valve was not opening. I've ordered the mixing valve and plan to replace it as soon as it comes in.
May 20, 2009 | Kenmore Washing Machines
Water will not stay filled in tub on rinse cycle
It sounds like a siphon issue.
Check that the drain hose does a high loop before it goes into the drain pipe. (ie. drain hose loops above the water level inside the tub). Make sure the drain hose is not pushed too far down into the drain pipe. Also if the drain hose is sealed to the drain pipe this will create an airlock and a siphon will occur, allow air to enter between drain hose and drain pipe connection.
This should help you but if there is still a problem let me know and I'll try to assist you further.
Mar 21, 2009 | Maytag Washing Machines
Temperature Control Problem
is washer less than a year old? if so call reapir ..there was an issue with the temp controls on a small number of those machines they use an electronic control in what looks like a mechanical switch..if over a yr old could still be a temp switch but be sure hoses are connected correctly and on a rinse cycle the water does come in hot ..don't worry too much about wash cycles temp is controlled to to prset temps and is based on final water temp in tub after fill not incoming water temp
Aug 06, 2008 | Whirlpool WTW5500S
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
97 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
