Question about Kenmore Elite 21086
21086 reading sl
Im just using a cheap soap.. what kind of soap should i be using.. is there a special soap for this type of washer.. When i did go to the link to find the manuel it states that it cannot be found. .thank you
    President:
  • 1,294 Answers
If it is top loading one, you use powders for 'top loading machines'. If yours is a front loader pl use powders for 'front loading machines'. It makes a big difference in cleaning.
Posted on Feb 23, 2008
I got a Kenmore HE2 front loader washer used with no paper work how much soap and what kind can I use?
Read the recommendations on the detergent box. The amount required will depend on the type of garments you are washing.
Apr 17, 2017 | Kenmore Washing Machines
What kind of soap is used in a pressure washer
Any water soluble washing agent ... depending on what you are washing. Some are not good if you are washing siding and will get the windows wet.
Oct 10, 2014 | Simpson PS3200 Powershot 3200 Psi Direct...
My 3 month old washer suddenly started leaking from underneath. There was a code displayed of a 5d, but the washer drains into a laundry sink, there are no kinks in the input line.
The washer is detecting too much soap. Make sure that you are using HE (high efficiency) soap Do a clean washer or hot cycle once a month with bleach or white vinegar with no clothes in it. Your washer only uses half the water that a regular machine does. The HE is specially designed for front loaders and these types of machines
Jul 11, 2011 | Maytag Bravos MTW6600T Top Load Washer
I bought this washer second hand, but the is no manuel with it.i would like to know what kind of detergent it uses dry ,liquid , or special type. thank u
Hello. If this is a newer washer of the HE type, be sure to use HE detergent only. IF it is not HE, do not use HE detergent. Instead use dry or liquid and remember this less is more! DO not use more detergent than it takes to get the job done. Start with one tablespoon of liquid or 2 tablespoons of dry and see how it does. As long as there are a few suds during the wash cycle you know you have enough soap. IF you have hard water you may need to increase the amount a wee bit if you are not seeing any suds during the wash cycle. Joe
4 thumbs up please. ty
Oct 18, 2010 | Kenmore Front Load Washer
Type of detergent in front-loading washers
yes make sure the box of detergent says HE on it. and read the directions on the soap box for load size and amount.
Jun 20, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Smell from washer sounds like water still in washer
neptune washers are the only front loaders that have a counter balance system and they do have water in them to do this. water sound is normal.
when you are having an odor, it is from using the wrong soap or too much of the right soap.
you need to be using "HE" type soap and dont use too much. what you are smelling is soap residues that are not getting rinsed out from the unit.
they do make a special cleaning tablet called "affresh" and it is designed to clean out these residues.
also your washer will have a " brush" type device around the front of outertub where the inner tub meet.
it is between the tubs and will collect debris and can look nasty when dirty.
clean all you can see and then try to run 1 cup bleach thru unit if you cant find affresh tablets. at lowes or sears.
then make sure you use HE type soap next time to prevent build up and odors.
Jan 05, 2009 | Maytag Neptune MAH5500B Front Load Washer
Laundry Detergent
this usually depends on the type and brand of detergent you use. for example if you use standard detergent and it takes 1 cup, then you use concentrated detergent and it takes 1/2 cup. you have to check the detergent container for proper amount to use. for most detergents it is around 3/4 to 1 cup of detergent.
Ps. dont forget to rate my answer please. Thanks.
Dec 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Problems
Greetings tammym545,
Generally an EFO error on a front load machine is caused by using too much soap, or the wrong type of soap. Ensure you are using HE (High Efficiency) soap in your front loader. HE soaps are specially formulated front loading units to be low sudsing, which is essential to a front loader.
Thank you,
Agent Dort
Go Ahead. Use Us.
Apr 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite calypso 21086 top load
SL = Suds Lock
SL is a suds lock code it can be caused by the drain pump not draining the water, too much detergent, non HE detergent, or extra heavy loads, try running it empty, if code persits it is a computer/main controller/timer failure
The control should flash this error code if it cannot detect the lid switch opening and closing properly.
This error code may also be used if there is a disagreement between the motor and machine controllers on the state of the lid switch.
The control should not allow the unit to run in this condition. This code will also appear if the user presses the START key while the lid is open.
Open the lid or press STOP/CANCEL to clear the display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 20, 2008 | Kenmore Elite 21086
Washer kenmore elite calypso 21086
promblem with the lid switch is it happing durning the drain spin cycle
Washing Machines Logo
51 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
