Question about HTC Touch P3450 Smartphone
Upgrade Problem When I try to install New_Blue_Touch_ROM_V4.0 on my HTC elf(Touch), phone going in hang screen with three colour line and going on and try to hard reset message come for a moment that seraching SD card.Why? I hear that through sd card booting file or bootloader file can help for this problem.What can I do for install this new version or try for going to original position before installation.From where i download this booting file and what name of this file?
I am unble to install dictionary in htc 3400.
Posted on Feb 25, 2008
I upgraded my htc touch elf 0100 today. but after upgrade it does it start then show "smart mobility " logo then switch off. I used onyx_5.5 for upgrade. I am in really trouble PLZ help me..........
1.have you gone through the instructions from ROM cookers. 2. put the mob on recharge and try to restart. 3. have u done a hard reset after rom update 4. try xda forum
Nov 03, 2009 | HTC Touch P3450 Smartphone
Problem while upgarding ROM
try hard rest..
if not the instructions on upgrading your rom strictly said if done wrong it can turn your phone into a brik.
try www.xda-developers.com for a soloution as they know more than me so it could be possible..maybe.lol
Aug 10, 2009 | HTC P3300 Smartphone
Screen hang
try hard reset.do back up before proceed.
May 23, 2009 | HTC Touch Pro Smartphone
Htc stopped working it hangs on home screen
i had a hard time understanding your question- but iim guessing its a software glitch.... what i did to reset mine was redownload the telstra rom from the htc site (htc.com/au/- then go support- then in dfrop down choose htc touch hd- then click download on htc toucch hd rom upgrade asia- then choose telstra settings and download- should be like 100 odd mb.... once installed connect hd to com via active sync (make sure more then 50% battery) and open up this rom update... follow installation instructions and let it run (all automatic- only for htc touch hd tesltra bought in aus) - be aware that this will wipe all stuff on the phone (not memory card) ie calendar contacts (so backup using active sync b4 update your rom) after all this turn on your phone again and it should start up like the first time u ever turned it on ie touch calibration and time/date etc (this should fix any software glitches)
May 22, 2009 | HTC Touch HD Smartphone
Htc p4550 problem with the screen
It seems that that your phone is stuck in bootloader mode. You will probably need to reflash it. For all the information on flashing a new ROM, you can visit http://forum.xda-developers.com or take your phone to the service station.
NOTE: Flashing the ROM incorrectly can make your phone dead forever!!!
Mar 30, 2009 | HTC Touch P3450 Smartphone
HTC Touch was stucked up after an error while upgrading to WM 6.1
i think u have tried to upgrade thru custom rom bcoz this pda came with WM 6 only so u tried to upgrade to 6.1 thru custom rom procedure and it seems like something went wrong and u get a boot loader screen tri color with code written SPL 1.XXX on it dont worry i can help u in this go step by step as soon as ur problem is resolved leave other step
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then try this
download Hard SPL 3.1 from here
http://forum.xda-developers.com/showthread.php?t=445666
install it as described in the instructions inside the zip file
and then Rom Lite version for ELF from here
http://forum.xda-developers.com/showthread.php?t=451100
first install hard spl 3.1 as directed on ur pda and then update to custom rom from the the file downloaded
pls rate me FIXYA if it helps
Mar 14, 2009 | HTC Touch P3450 Smartphone
P3400 audio manager dosen't play any mp3 and i can't put any mp3 as aring tone
alternately u can do this
if ur phone is HTC P3450 ELF or HTC3452 ELFIN there are 2 versions of this device then go to start >Programs>fileExplorer>select music file u want to set as ringtone, and then long tap on the file for like 4 sec a menu will appear u can select set as ringtone and ur file will be set it is the std procedure for it
and about that HTC audio manager u can check for updated ROM from www.htc.com >ur region >support and then check if new ROM is availble it i will address ur issues of audio manager
but if u really want a new look for ur PDA and want to make it like touch HD then my friend i will suggest this but at ur own risk but the results are really worth it
see this update to CUSTOM ROM for ur pda and u will get more free memory for programs and storage i know it is a big rpoblem in this pda and u will get new look like touch hd
and then Lite version for ELF from here
pls rate me FIXYA for my response i have lots of tweaks for PDA's
Mar 06, 2009 | HTC Touch P3450 Smartphone
Stuck on windows boot up screen
Regarding with your HTC Viva / Elf
Try hard reset with phone in "OFF" state following this instructions if it will do;
1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button under the battery cover at the top
of the device.
2. Release the stylus, but continue pressing the TALK and END buttons until you see this message on the screen:
Warning! Your device will be set back to factory default settings. Please ensure any additional installed programs and/or user data have
been backed up before a hard reset is performed.
3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 03, 2009 | HTC Touch P3450 Smartphone
Htc touch phone
you'll have to install a different rom, in fact a WWE one, it stands for world wide english. head on over to www.xda-developers.com and look in the htc elf topic, don't forget to jump-spl the phone before flashing a different rom
May 24, 2008 | HTC Touch P3450 Smartphone
HTC Touch P3450 Smartphone Logo
170 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
