Question about Summagraphics SummaSketch III Graphic Tablet
Skipping and Shaking cursor
My tablet was just fine for the first two months, than all of a sudden it started to get bad. The cursor, whether with pen or mouse, literally shakes and skips rapidly, and makes very jagged lines. Ive reinstalled the driver, checked the balance of the sensitivity, and such. Nothing works!. It wasn't as bad when it started ,but it gradually yet really quickly got worse and worse every time I used it.
I than tried it at a school computer which had CS3 and some other various tablet driver things, and it was just fine. I'd really like to fix this asap, I cannt make decent artwork or ink with consistant lines, and it is VERY! fustrating.
x_x anyone to help? I hardly want to deal with phoning a company, those are always such a huge hassle and hardly do any good, Im no good over a phone.
Mouse is trembling, shaking, we have reinstalled software, checked settings, uplugged, used system restore, tried different board & mouse, changed out keyboard, nothing is working.
  • novasystems Oct 01, 2008
    When the tablet is enabled my cursor traces a small circle around a fixed axis  wherever it's placed.
    No matter where I move the tablet it still occurs.  I'm wondering if this isn't it tracing a sine wave noise signal that's being backfed from the motherboard's integral serial port.
    I'm going to get a pair of ferrite donut noise filters and wind both cords a few turns through them.
    Problem Solver:
  • 9 Answers
Both options should be tried. A generic power supply usually does not fix this problem however the Summagraphics power supply will (Has better filtering and regulation) need a good quality 12VDC 200 mA power supply, use the plug from your old power supply as the plug size is not always easy to find the correct one. Think the center pin needs to be +ve.
These guys still have all Summagraphics parts and digitizers and may be able to help you: http://www.interworldusa.com
Gerry
Posted on Oct 16, 2008
I had a similar problem years ago w/ my ss III 12x12 that had worked flawlessly for years. I talked to tech support and they said move it away from monitor (crt) or other source of RF interference - this did not help mine. I tried replacing the power supply w/ generic one - no help. I noticed that the power supply voltage was spiking when check w/o load. After talking to an electric guy I know, he suggested a voltage regulator. Finally I built a home-made voltage regulator and wired it into the generic supply line -Problem solved This was about 10 years ago - still working good today.
Posted on Apr 05, 2008
4 Suggested Answers
SOURCE: Skipping and Shaking cursor
There is a problem with the compatability of your tablet and your monitor. You either have to change your monitor to a different refresh rate or simply move your tablet abit further way from your monitor. If possible, you could change your tablet to "single mode" (depending on your tablet).
Posted on May 28, 2008
I have exactly the same problem as you, my tablet worked perfectly for the first three months and then started to act weird, shaking and skipping screen areas, even if i only touch it with my forearm.
Uninstalling/Re-Installing drivers didn't solved anything, so i started switching my tablet to different usb ports in my pc, and from one to another, the problem got a lot better. It didin't solved it, but works "decent". So, comparing yor experience with mine, it's probably an usb-port problem, rather than the tablet itself i thik.
I will test it in othe computerts to see how it goes
Posted on Aug 10, 2008
I own a Graphire2 and I have often had the cursor shake like this. Usually unplugging and replugging the USB cable from the computer does the trick... and if it doesn't, restarting the computer usually does. I've never really had to fight with drivers.
Posted on Oct 28, 2008
How do I get my pen tip working?
Pabz, try uninstalling drivers and its software, then reinstall.
Apr 16, 2016 | Genius EASYPEN I405X 4 X 5.5 TABLET
Tablet pen cursor moves in the wrong direction
Wow been there my self on my gateway tab also. I found by trying this to be a issue with the FLICKS settings and needed to update the firmware and re calibrate the pen without flicks or other short cuts u might use. Also if u just bought this PEN locally u might contact the seller for assistance and if not able ask to exchange this one to test out if its on your side of the problem or just a issue with this model pen. I often do not try to do to much testing of hardware that might cause more questions and often more problems later. I recommend before u start trying out possible fixes that change the config of now a system that works with 3 pens and has in past what might u change could not help us determine if its your side config or if its a bad pen or is it a known issue and if it is we might beable to at least leave a trail of what we did incase we need to undo what changed.
Please if u could tell us the make of the pens that worked and the make and model of the one that don t... also u might see if anyone else u know could test this pen too on there tab for out ruling works or not.
Good luck ill follow ur posts
Chadman
Dec 26, 2013 | Monoprice 8x6 inches graphic drawing...
Tablet pen's cursor skips around in 3 places?
The cursor skipping in three places is apparently caused by the connectors inside the tablet getting dirty or corroded.
Fortunately, you can easily fix this problem yourself! All you need to do is unscrew the back of your tablet, unplug the connectors and clean them with a q-tip dipped in alcohol.
There is a video on YouTube that shows you step-by-step how to do it(it's easy!).
It's called: Howto fix dead areas on any graphics tablet and it's posted by riodroid.
Here's a link to it: http://www.youtube.com/watch?v=ff7Vw-0kPsE
Hope this helps!
May 14, 2013 | Adesso CyberTablet 12000
My Genius Mousepen 8x6 tablet isn't working with the pen. If the pen touches the tablet, the light lights up, but the cursor doesn't click and it won't move either. The mouse is working fine, though.
My i608 pen stopped working today. I've had it for a month. The mouse was working fine, but the pen wouldn't work at all. Then I left the mouse on the pad and used the pen while the mouse was on the pad, and the pen started working again. Now it works even without the mouse on the pad. Did it re-establish the radio connection or something by doing that? Anyway, saved me the $25 replacement cost.
Nov 25, 2010 | Genius MousePen 8x6 (MOUSEPEN8X6)
Tablet Pen wont work?
i had this problem for a while play with the settings or re-install it :) mine's back to normal now :) xxx
May 28, 2010 | Wacom Bamboo Fun USB Tablet with Cordless...
Jul 31, 2008 | Genius MousePen 8x6 (MOUSEPEN8X6)
Mar 17, 2008 | Wacom Intuos3 6X8 USB with Pen&Mouse [...
could be that it is too close to the monitor - radio frequencies interfering -- try to put tablet farther away from wherever it's plugged in...
Feb 15, 2008 | Wacom Graphire4 4x5
Why does my tablet suddenly start to randomly click and drag?
Sometimes the tablet (especially ones with buttons at the top such as Cut, Copy, Paste etc) reacts to pressure and not the tablet itself. Make sure theres nothing over them, that might help.
Aug 20, 2006 | Aiptek HyperPen 12000U (HYPERPEN12000U)...
Open Questions:
We have a digitizer we are trying to resurrect: SummaSketch III with 4-button Diamond Puck 12 x 12 MM compatible version 1.91 Win XP SP2 (version 5.01 build 2600) Tablet Works 7.46.0619 com1 All buttons work and are assignable The puck works in mouse mode. In WYPIWYG mode there seems to be some problem: In Tablet Works Control Panel, the digitizer area doesn't stick - the (almost) whole digitizer area is still used; a small selectable area cannot be defined. I use this in AutoCAD with the Wintab Comaptible Digitizer ADI 4.2 - by AutoDesk. AutoCAD will recognize the tablet and allow me to configure regions and a screen pointing area. Menu items on the tablet work and the screen area allows geometry selection. Here's the problem (you could feel it coming couldn't you): Counting up from the lower left corner of the tablet The tablet "sees" (steady indicator light) from about (4.75cm, 4.3cm) (my ref: X-5) to (28.0cm, 26.5cm) (my ref: B-27) In the GTCO tablet configuration utilities the cursor can paint the test screen area from the lower left corner to about 75% of the test screen area up and to the right. A few years ago we had a problem with the puck: A button wasn't working. We repaired it. The cross-hairs cover fell out and the coil wire broke, we resoldered it. I don't remember clearly but we may have tried to replace some of the coil wire. Questions: How can I repair this here myself? If the coil is not the correct sensitivity will that cause the symptoms we have? What is the correct wire size and number of turns for the coil? Any suggestions on how to rewind it? The felt on the bottom of the puck is worn. Do you have a suggestion for a replacement material? What is a good way to keep the cross-hairs cover from falling out? We are a not-for-profit NGO that works to help rural villagers have good empolyment by making building materials on a small scale. We use AutoCAD to design buildings that use their materials and equipment and tools for them to produce the materials. We also mentor interns from local and foreign universities and colleges. We would appreciate any help you can give us. Sincerely, Geoffrey
Aug 31, 2011 | Summagraphics SummaSketch III Graphic...
Summagraphics SummaSketch III Graphic Tablet Logo
480 people viewed this question
Top Summagraphics Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Summagraphics Computer and Internet Expert? Answer questions, earn points and help others
