Question about Epson Stylus C82 InkJet Printer
Printing when i try to print 6x4 photos it will only print 5x7 and cuts the tops of the prints
Driver
Posted on May 12, 2008
I have Hiti P510S photo printer which was working very well, but now when i issue a print command, it gives me an error message like "PAPER ROLL MISMATCH" even with all consumable well fixed. What do i do?
Double check the ribbon chip and make sure contacts are clean. Also make sure it is for the 4x6 paper size. If it is a 5x7 ribbon it will not work. Have you printed 5x7's before? If so this is probably the issue.
Also check to make sure firmware is up to date. . I hope that helps!
Oct 23, 2013 | Hi-Touch Imaging Hi Touch Imaging...
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Cannot print 5x7 photo on Photosmart D7360,
if you dont hvae 5x7 option you can creat your won setting open printer adn faxes ...>goto file ..>server properties there you can creat it......
Oct 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Cannot print 5x7 photo with i550 printer. What do
The i550 is capable of printing 5x7, the print software you are using may not be capable. The paper is loaded in the feeder lengthwise all the way to the right. If you are getting error codes, that's a different story.
Aug 13, 2009 | Office Equipment & Supplies
Two lines show on my 5x7 prints
If the machine has mainly printed 6x4,When you
go to print 7x5 the edges of the head and rollers
tend to be dirty and will leave the two stripes along
the edge of the prints.Use the cleaning ribbon and the
sticky pad supplied with a new box of paper to clean the machine.Depending on how bad it is it may take a few try's.To do this switch the machine on and enter the control panel by tapping twice on the top left of the monitor- It will ask for a four digit code - Uless it has been changed this will be 9999 click
Enter/Ok - then click on the top far right ikon and
the screen you see will have a greyed out ikon
bottom middle - Now replace the print ribbon with
the white cleaning ribbon supplied with the machine
and the greyed out button becomes active - Click on
this button and the machine asks if you want to clean
it click Enter/Ok - About 10" of paper will then be
driven from the machine place the sticky pad as per
the drawing on it onto the paper and press Enter/Ok
- The paper will move in and out a few time and then eject a big piece and some small pieces of paper - Then remove the white cleaner ribbon and replace with the print ribbon and press the green return button
in the bottom right of the screen to return to normal use.This should be performed every two - three boxes
of paper.
Jan 21, 2009 | Sony SnapLab UP-CR10L Digital Photo...
Pixma ip 3000
I think that if you use the bottom tray to load the paper, you can use the different sizes of paper to print. Make sure to click the second button inside the lid that shows the direction the paper is fed into the printer. hope this helps!
Jan 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Print Problem
it's better to configure the paper size through the printer but the best way to do it from the software on the pc. when you go to print it, select file, print as you do, then go to paper size and select manually from the paper options and then click ok and print it.
May 08, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printing 5X7 photos
try aligning and cleaning the cartridges
hope this helps
Apr 12, 2008 | HP Photosmart 2575 All-In-One InkJet...
6x4 Print Problems
Try doing a media calibration press "COPY" & "CANCEL" button together
Feb 22, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Printing photos onto 6x4 inkjet paper
which is the model of the printer, not all the printers permite to you do this
Oct 30, 2007 | HP PSC 2175 All-In-One InkJet Printer
Epson Stylus C82 InkJet Printer Logo
48 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
