Question about Onkyo TX-DS676 Receiver
Onkyo TX-DS575 My reciever's sound keeps shutting off. I can be watching a DVD, cable, or playing a video game and the sound shuts off. All my connections are fine and have had no changes in anything else the pictures play fine also. I am not a high tech person and I have read other post about memory and changing switches inside that is over my head. I need a solution the average joe can understand and try and fix or take somewhere else to fix.
  • alexx21 Jul 27, 2008
    I have the same problem as well. The only difference is as soon as I turn the volume up it shuts off. I took the cover off and all the fuses look fine.
    Scholar:
  • 154 Answers
I would check your wireing in the system end and just make sure nothing has loosened up over time this can happen even if you don't move the system. The only other thing I can think it maybe is the system is overheating and shutting down. When it does it again carefully feel around the system particularly the rear of the system if it is really hot it is probably shutting down. Is the cooling fan runnig?
Posted on Jul 25, 2008
I have lost the remote control of my Onkyo TX-DS575 AV reciever/DTS Amp and cannot find one in the market. I have used a universal remote which had a couple of Onkyo codes with it but it doesn't work. Is...
Amazon.com, MyRemoteControls.com, and Remotes.com all sell a replacement remote for the TX-DS575. I have also seen the Onkyo TS-DS575 receiver with remote listed on eBay for as low as $35. Keep looking; the remotes are out there.
Jan 22, 2014 | Onkyo TX-DS575 Receiver
Remote doesn't operate reciever
Hello Fixya customer,
Thank you for your question.
Please determine if the "Audio" button is actually working.... after pressing the audio button, can you still control the DVD, if not then the remote has switched to the Onkyo. Although, this is not 100% conclusive, unless you have a 2nd remote to test the Onkyo with, it provides a sound basis to proceed.
Assuming the remote is transmitting and the IR receiver on the front of the Onkyo is not otherwise blocked, likely faults include the IR receiver, input to the Micro processor, and the Micro processor.
The most probable fault is the IR receiver.
Thank you for using Fixya, and if I can help you further, please let me know.
Apr 29, 2010 | Onkyo TX-DS575 Receiver
Dolby digital output
sounds like you are watching cable.
Nov 03, 2009 | Onkyo TX-DS575 Receiver
PCM vs Dolby Digital
OK, I just figured this out. Go to the audio options in your DVD player and switch from pcm to bitstream. Now my movies sound right again.
Nov 16, 2008 | Onkyo TX-DS575 Receiver
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Need fiber optic input jack for Onkyo TX-DS575
Had it ever worked, or are you setting it up for the first time?
Have you ASSIGNED the digital input in the menu?
Dec 18, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 turns off after about 10 min.
it could be a failing speaker causing the fault. Disconnect one speaker and run it to see if the problem persists and repeat with a different speaker until all speakers have been disconnected and the unit run to failure. If it stays ok, with a particular spkr off, it's the speaker. If it shuts down no matter which ones disconnected, it's probably a crack on the PCB which expands as it heats and causes shutdown.
Dec 16, 2007 | Onkyo TX-DS575 Receiver
Audio problems
Hi, I just started having the same problems with my Onkyo TX-DS575. I have to play with the DSP buttons...the A/B speaker button...and now it has gotten to the point where my family and I lift the receiver up in the front, and slam it back down on the shelf and then hit the DSP buttons again and eventually we get some sound. This unit was already fixed once by Onkyo right after the 2 year warranty ran out for a similar problem. They returned it working...but scratched. This is the second Onkyo receiver that has died an early death within 15 years. I love Onkyo's styling, ease of use and sound, but I found the best way to solve this was by purchasing the Yamaha RX-V861 this week. I am done with Onkyo. Scotty D, Middletown, NJ
Aug 20, 2007 | Onkyo TX-DS575 Receiver
TX-DS575 reciever
Normally you hear a clicking sound coming from the inside when you turn on your amp. That's the sound of the magnetic circuit breaker (switch). If you tap your amp to turn it on, and if the amp gets turned on after you did it:), then I suppose the problem is on the relevant switch.
Jul 04, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS676 Receiver Logo
214 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
