I need help assembling my new blade, gaskets and washers for my glass waring blender jar. I put it together and it ran a bit but then tightened up and wouldn't work. It also started leaking, so I figured I'd put it together incorrectly. In what order should the pieces be put together?
2 Other Users Have The Same Problem
Comment by Guest, posted on Aug 21, 2008
CALLED CUSTOMER SUPPORT. NO HELP
PERHAPS IT IS ASSEMBLED WRONG. BUT, I AM NOT ABLE TO GET THE BLADE DISASSEMBLED FROM THE BASE.
Comment by debbieblue, posted on Mar 12, 2008
how do you change the blade for the anniversary edition waring blender model 34BL87? i bought the replacement blade assembly but there are no instructions!!! thanks to anyone!! it doesn't look easy!
Rating: 0%, 0 votes
------- To remove the blade assembly you would put a towel inside the jar and hold the blade still. Pay attention to the order of the washers, gaskets and all. Unscrew the wagon wheel off the underside of the jar Unscrew the hex nut off the underside of the jar. Pull the whole blade assembly out from the inside of the jar. When putting a replacement blade assembly in, put it back in in the same order Tighten the hex nut on the underside of the jar with a wrench, only by hand...if you tighten it too far, you will crack the jar. If you do not tighten it enough it will leak. Screw the wagon wheel back on. ------- The only thing I did differently was to remove the top nut from the inside of the blender using pliers while holding the bottom rigid. Then the main post attached to the wheel pushed out the bottom. Hope this helps!
Was this solution helpful? Show your Appreciation by rating it:
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Can you Help with these Blenders problems?
cuisinart cb-18 smart power
Lights/LED lit up, but blender...
blade part replacement
one out of 4 blades
need a part
