Question about Toshiba 61HX70 61" Rear Projection Television
FUZZY PICTURE CONVERGANCE IS GOOD
Is there any way to clean the mirror or lens?
  • 7381 Feb 27, 2008
    It worked!!! Thanks!
    Scholar:
  • 135 Answers
Hi There!
You can certainly clean the mirror and lenses. surgical alcohol and a soft cloth should do the trick. Be careful when removing the screen. It is fragile and the slitest bump can damage it permanently. Also be careful not to turn or bump the lenses. Thus can result in many hours wasted on realignment. Good luck, JUS004
Posted on Feb 26, 2008
  • Justin Smith Feb 28, 2008
    You are welcome!
Hello my question is about what I think is a mirror issue on my n75 Nikon camera. When I look through the viewfinder the picture appears fuzzy. I looked closely at the lens and it does not look like it...
First off, with no lens attached, it will always be fuzzy, there is nothing to focus the light. Second, if you're looking at the mirror, you should be able to tell if it's dirty - if it is, glass cleaner and a soft rag are all that are required.
I'd suspect however that neither are your issue. Either your focusing screen is out of place or damaged, or your camera's diopter correction (if it has it) has been moved, Look for a small dial right next to your viewfinder with a +/- on it, and with the lens attached, and focused, turn the dial until everything is in focus. If your camera has this dial, it'll be usually on the right side of the viewfinder window.
If it does not have it you'll need to seek a repair shop to check your focusing screen since the mirror is 99% not going to be the cause of your problem. If there are no shops locally, google KEH Camera. It'll run you $35 for an estimate, waived if you decide to have any needed repairs done.
Sep 08, 2011 | Nikon N75 35mm SLR Camera
Fuzzy picture...direct cable says its in the tv itself...unplugged ,plugged back in removed coaxial and replaced checked all plug ins to no avail..
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV by removing lots of screws at back to clean it inside.
Thanks.
Apr 18, 2011 | Televison & Video
Fuzzy picture...started when first turned on tv,after a few minutes picture be came clear.tv now is fuzzy all the time.model #50vx915 ser.#v4k000487
TV seems dusty inside, please clean optical lens, rear mirror and front screen of TV to get better picture, need to take off back of TV to clean it inside.
Thanks.
Mar 30, 2011 | Hitachi Televison & Video
Fuzzy picture
have you taken off the screen and tried to clean the lens as well as the mirrors inside the set?
May 04, 2010 | Sony KP-53XBR200 53" Rear Projection...
Pictures fuzzy when you look through the viewer.
The viewfinder and the picture lens are totally separate. If it looks fuzzy, and then comes out fuzzy, the capture screen inside needs cleaned. The main lens and viewfinder lenses should be cleaned too.
Get estimates before you say yes to the work. It might be cheaper to buy another camera, unless you can do the work yourself.
Aug 06, 2009 | Sony Cyber-Shot DSC-P52 Digital Camera
How hard is it to open up a Hitachi 57: Rear
there are just a series of screws to remove the the back and the whole thing opens up. Not sure what to have you used to clean the bulbs off probably just a clean soft electronics cloth. No alchol or windex.
Mar 27, 2009 | Hitachi 57S500 57" Rear Projection...
RCA projection tv is blue and fuzzy
may be convegence try turning down the blue screen and see that that does see if the picture clears...
Feb 04, 2009 | RCA Televison & Video
How can I clean the mirrors on this tv?
to clean the mirrors you must remove the screen first there are several screws in the back to remove the screen. then there is a mirror shaped like a polligon clean this with a dry cloth do not use a paper towel. soft colth must be used on any optical surface. then clean the optical engine lens in the same manner. them the large mirror in the back. remeber if you leave a defect on any of these surfaces it will be amplified by the screen. this system relies on a lamp to provide bright picture so replace that as well. this should be a part of your anual cleaning agreement of the after market warranty you purchased assuming you bought one. dim picture = lamp, fuzzy, dim, dull picture = dust
Feb 10, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Scratch appears in photo's
The nice curvy pattern looks like a hair but I supposed it could be something else. Are you sure you've cleaned both the front and back of the lens?
Sep 19, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Toshiba 61HX70 61" Rear Projection Television Logo
116 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
