Question about Garmin GPSMAP 3010C GPS Receiver
GSD 20 power problem
I can not get the souder to power up I have switched powere cables and know they bouth work I also sent it back to garmin for replacement and still have same problem
  • rmeken Feb 25, 2008
    no the unit will not POWER at all no lights flash or even start to light I just find it hard to beleive i had 2 bad boxes I was wondering does the transducer have ant issuses that could cause this not to power up?
    Novelist:
  • 113 Answers
I'm not sure what you mean by "cannot get the sounder to power up". Are you not getting power to theGSD20, or are you not getting the sounder to display on the screen? I can probably help you with this but I need some more information.
If you are getting power to the GSD 20 sounder, it will have a flashing LED next to the cables that plug into the GSD 20 box. What color is it and what is the flash pattern (how many flashes, and fast or slow?) When you power up the GSD20 does the color or flash pattern change.
I'll watch for your response here.
Posted on Feb 24, 2008
Where you plug in to charge is broke
Hi.
If you broke the lighter socket on car dash, replace it.
If you broke the cable replace the cable. Here the spare:Garmin Power Cables
If you instead damaged the power socket on your Garmin, call the Garmin number listed in the owners manual. The Sat Nav must be sent to Garmin for repair:Garmin ' Contact
Next time use a Suction Mount Windscreen Holder
Regards.
Ginko
Dec 15, 2011 | Garmin StreetPilot c340 GPS Receiver
My GSD 21 is mated to a Garmin 3210. Bought both componants new. Every single year since new it works 2-3 trips. Then just doesn't come on. Have to send it back to garmin who so far have waranted...
The GSD 22 is discontinued. I would not buy any electronics that are discontinued, because there has to be a reason.
If I were in your shoes I would be looking a full change to either the brand leaders, Raymarine or Humminbird. I have had Humminbird since 2007 with a 798SI and since 2014 with a 998SI HD. 100% reliable for GPS and depth. Boat used twice a week May to October. The 998 has features to set a chart course and I do that when coming from Toronto to Port Credit. Humminbird also do full chart plotters, but in Georgian Bay, I wouldn't have thought necessary unless you use an auto-pilot. Uses Blue Chart maps.
You aren't the only one to have problems. Read the link below.
I did find this thought and there are others in the thread
http://www.thehulltruth.com/marine-electronics-forum/146766-installer-i-stumped-garmin-problem.html
Make certain that the transducer(s) cable is separated from any engine power cables. When those wires cross or are bundled together, the highly sensitive sonar signal gets polluted with high amp noise bleeding off the engine wires, and you're lucky to get any signal.
To test if this is the problem, shut your engines off and see if you get a good sonar view. Then start the engines and see if the same sonar quality is displayed. If it degrades, you've got the current bleeding problem.
I had this problem when I installed the new gear (Furuno 585, Airmar b60) and ended up re-routing the transducer cable using some "wire hangers" to keep the transducer cable away from the others. Now I get a firm fix on the bottom at all speeds and the only time the display gets lost is when I reverse the starboard engine, from air bubbles under the thru-hull.
GSD 21 with 3210 problems - Google Search
Mar 21, 2017 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
I am having trouble both registering my Garmin 1100 GPS and ordering Accessory Parts as there doesn`t seem to be an 1100 on the list given. I would like to order an AC adapter cable p/n 010-10723-00 an a...
First, I would suggest you reset the unit,if that doesn't solve the problem, then you will have to update your garmin nuvi, I think its out of date and needs to be updated. Follow the procedures below on how to update your garmin nuvi:
1. Plug one end of the USB cable into your GPS and the other end into your desktop or laptop computer. The GPS device will load the appropriate driver automatically, and a message on your GPS tells you that it is connected to your computer via USB.
2. Open your Internet browser of choice and type in the following web addres: "http://www8.garmin.com/support/collection.jsp?product=999-99999-27 "
3. Download the appropriate version of the software for your computer (Windows or Apple) and Install the WebUpdater by following the wizard (accept defaults).
4. Click "Start," "Programs," "Garmin" and " WebUpdater" to update your firmware and your maps. Periodically check and make sure your software is current.
Also, in case you don't know how to reset your garmin nuvi, you can follow the steps below: There are two types of reset;
Performing a Standard Reset
1. Slide the power switch all the way to the left (with the Nuvi's screen facing you).
2. Hold the switch in the position for at least eight seconds.
3. Push the switch to the right to power the Nuvi back on.
Performing a Factory Reset
1. Turn your Nuvi off by sliding the power switch to the left.
2. Press your finger against the bottom right corner of the touchscreen. Hold your finger in this position.
3. Slide the power switch to the right to turn the Nuvi back on. Continue to hold you finger against the screen until you see the factory reset prompt. Tap "Yes" to perform the factory reset.
Concerning the parts, you can order for the adapter from this amazon link; http://www.amazon.com/exec/obidos/ASIN/B004AL7B7K/randomize0d-20
For the USB, visit; http://www0.shopping.com/garmin-usb-cable/products?IVD=1
Or contact Gamin via email or phone and request for the Adapter and other accessories needed. They should send it to you or direct you to a dealer closer to your vicinity where is can be gotten.
Visit; http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Good luck.
Mar 01, 2011 | Garmin GPS
Unable to track the bottom
I think you need to level the transducer. You have it pointed way out in front of you so that when you're going fast it is able to bounce the signal off the bottom and it comes back to where the boat has traveled to. When you're going slow you're bouncing it out in front of you but it comes back up in front of you. Sorry but I can't find a picture of a Garmin transducer. Hope this helps.
Jun 02, 2009 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Garmin Golflogix GPS-8 New unit, new batteries, unit won't turn on after hold power switch.
If you downloaded the new software on a mac it doesn't work. You call the company and will receive a new device, then send the bad one back. They take care of shipping.
Feb 18, 2009 | Garmin Golf Logix GPS
Power switch not working.
If you can't you can sent it in to garmin
Feb 01, 2009 | Garmin nuvi 200W GPS Receiver
Sounder not working
Interference like that is usually caused by electrical noise. Does it happen when everything else on the boat is turned off? If the answer is no, then you can isolate the source of the interference by turning things on one at time. Follow your transducer cable and make sure it has not been damaged or altered in any way.
Also make sure that your gain is set to auto
The GSD 21 has an LED indicator light on it. If it detects a malfunction the LED will flash in distinct colors or patterns. In the troubleshooting section of the owners manual there is a list that explains what each flash pattern means.
Jul 24, 2008 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
Garmin GPSMAP 3010C GPS Receiver Logo
207 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
