Question about Irons
Rowenta autosteam iron dz 1700 r
Won't steam.red light continually flashes. rowenta autosteam model dz 1700 r
  • 24 Answers
The electronic device is faulty and need to change inorder for the iron to work properly.
Regards
alan
Posted on Feb 24, 2008
How do I fix iron?
If there is no heat, then the heating element has opened and is in need of repair.
Aug 29, 2015 | Rowenta Advancer High Pressure Steam Iron...
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
Sep 02, 2014 | Rowenta Irons
Does red light suppose to flash
follow this section troubleshooting and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2013 | Rowenta Effective DX1900 Iron with Auto...
How do I use the self clean button in the DW5080 Focus 1700 Watt Steam Iron
please read carefully the owner manual and get the information about how to use the steam.
download from www. fitness.manualsonline.com
God bless you
Feb 01, 2013 | Rowenta DW5080 Focus 1700 Watt Steam Iron...
Rowenta steam generator iron will not shut off the steam (continues to steam until resivior is empty)
see the pictorial, and proceed according
clean the mechanismo +passages+examine steam component for loose, worn, or broken and replace. God bless you
Sep 06, 2012 | Rowenta Steam Generator DG050 Iron
Rowenta d1700 red flashes and iron shuts off
I am on my 3rd or 4th Rowenta. I recently bought the Rowenta Effective, Model DX 1700. Once again, I am having the same problem as before, it shuts off after about 30 seconds. From what I am reading, many people are having the same problem. I'm going to have to guess, this is a product defect. Do I contact the company for a refund????
Dec 03, 2009 | Rowenta Effective DX1700 Iron with Auto...
Sometimes the auto shut off doesn't work and it
In poking around, I find way too many hits on the name which once was a good one while I lived in Germany. They have exploding irons, coffee makers that turn themselves on and can catch fire, even a 'lighter' (wasn't described) being recalled. If you have any warranty on that unit or if Target agrees to refund your purchase price, I wouldn't recommend trying Rowenta again-
Nov 10, 2009 | Rowenta DZ1700 Iron
Iron will not go on until you wiggle cord &ball
Rowenta DZ 9050 steam iron must be sent to Rowentas repair service in your area.
Local Fix shops will not work on them.
They have parts only.
Feb 19, 2009 | Rowenta Irons
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
Irons Logo
590 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
