Question about Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Picture I have a ps3 hooked up to video 1 and there are two white lines on each side of the screen. the remote was a piece of junk to begin with so i had to get a universal. by the time the game comes on im playing on about a 19" screen. i need to know if its the way the console is hooked up or if i have to find a remote that will access this impossible tv?
  • 167 Answers
Hi, check and see what format you are in 4.3-or 16.9 try 16.9 this is widescreen mode and should fill the screen, as for the setting on the tv, alot of these don't let you do much without the original remote. some universals may do the settings, it is hard to find one, that is cheap, and the replacements are costly(had to get one for a stereo receiver) and that was more than $100.00. good luck with that unit, hope this helps
Posted on Mar 09, 2009
How do you hook up a ps3 remote control to play games with the ps3 remote.
    1. Turn off your PS3 console and disconnect it from the power supply.
    2. 2
      Insert the USB cable provided with your console into an open contoller port. The controller ports are found on the left side of the front of the PS3.
    3. 3
      Insert the other end of the USB cable into the back of the wireless remote controller that you want to sync with the PS3.
    4. 4
      Reconnect the power supply to the PS3 and turn it on. The wireless remote control should sync automatically with your console. If it does not begin automatically, press the "PS" button at the center of your controller. This will begin the process. Once the sync is complete, you can disconnect the USB cable and the controller will communicate with your PS3.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
No picture on tv screen from ps3 console
It may be that,
1:
You have it on the wrong channel.I personally have had trouble with this.Usually on most modern televisions there is AV 1 2 3 4 and 5,CVI,and HDMI 1 2 and 3.Try each of these channels.
2:
You don't have the cords lined up.The three cords(in the order of Yellow White Red) must be lined up straight up and down.Otherwise the sound will be on one channel while the picture will be on the other.
Thats all I can think of,I hope it helped.
Dec 16, 2009 | Sony Playstation 3 (PS3) Console
No picture, sound or menu on PS3
Try booting the PS3 with the hard drive removed from the drive bay ( on the side) you just remove the small plastic piece hidding it and remove one screw. It's easy. Let me know what happens. Also make sure you also plug in the original red white n yellow cables too to check if it's just an hdmi issue or system wide.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 not turing on at right channel
hmm make sure that the hdmi hook up is completely and firmly inserted in the slot let me know if that wont fix it
Feb 09, 2009 | Sony Playstation 3 (PS3) Console
PS3 Video Connection--Lines on TV
this may be due to the fact that your ps3 will be set up to hd. go into video settings when you switch it on and this should solve the problem. i had similar problems and bought a hdtv until someone pointed this out to me. however once you have experienced ps3 in hd you will not go back!!! hope this helps
Jan 13, 2009 | Sony Playstation 3 (PS3) Console
Projection lights don't line up
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
PS3 60GB
Contact sony @ 1-877-253-SONY(7669) for a replacement unit
Sep 04, 2008 | Sony Playstation 3 (PS3) Console
Digital Cable problems
I would try:
making sure your ps3 has the red light on then push and hold it for 5-6 seconds.. try it 3-5 times let m know if it works
Jun 17, 2008 | Sony Playstation 3 (PS3) Console
Screen problem
use your remote and change to AV1 sys 1
Jan 03, 2008 | Legacy LSWR82IR 8 in. Car Monitor
Toshiba MW27F51 27 in. TV/VCR/DVD Combo Logo
203 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
