Question about Bissell 1960-3 QuickSteamer Plus Upright Vacuum
PROBLEM WITH MOTOR
I have my quick steamer for about 2 yeahrs,Only cleaned my carpet twice,It worked great,then I try it again a few months later,and it did not even start.My questions is should I have it fixed or it is cheaper to pay a new one.It should not happening so quick.
  • putzie Feb 29, 2008
    What Steamer would you recommend?Thanks for the advise.I thought to do the same, but still like to try different option.Again THANKS
    President:
  • 1,673 Answers
Sorry but the motor from Bissell is no longer available, they have obsoleted alot of the older cleaners & parts for them, and this model is one of them. I would buy new, even if the motor was available, it would cost around $60+, then also labor if you take it to a shop.
Posted on Feb 23, 2008
  • Lauren Junge
    Lauren Junge Feb 29, 2008
    There alot of good brands, Hoover is less troublesome then a Bissell, but they are both good cleaning machines. The main thing is to keep them as clean as you can after you are done using them, rinse them out with a solution of vinegar and water, don't slam them around, use care and they should last a while. But anything man made can and does go bad at some point.
Do I need to use any cleaning agent inside my steamer or spray it on top of the carpet then steam it
Steam cleaning is supposed to mostly eliminate the need for chemicals.
I suggest you check the steamer instructions or contact their customer service for advice before testing a small area of carpet for colour fastness that is usually hidden.
Nov 10, 2016 | Top Vacuums
Dirt devil carpet steamer diverter valve not releasing for furniture attachment
Hi there! If the trigger or valve are sticking this can be an indication that the valve may be clogged with soap residue. Try soaking the trigger end in warm water for a few hours. When you use the hose again, be sure to prime the trigger by pumping it about 30 times then squeezing it for 30 seconds to get the solution to flow. Hope this helps!
Jun 22, 2014 | Dirt Devil Easy Steamer Upright Wet/Dry...
Hoover spinscrub
I would be careful in mixing solutions with different machines. The steamer carpet cleaner applies the cleaning solution differently than the spin scrub. If anything, I would delude the solution before using it in the shampooer. The steamer automatically deludes the solution, the scrubber directly applies a thick coat.
Elisa Jed ' http://www.babayans.com/en/
May 01, 2014 | Vacuums
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
Bissell 6591 operating twice as loud as before.
Hey Mike! Excessive noise can be contributed to dirty filters or clogs. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1421&cid=ccsocial
Feb 03, 2013 | Bissell 6591 Power Trak Revolution Bagless...
Bissel powerwash 1690 does not dispence water
Hey George, not having spray when you're ready to clean can be frustrating.
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jan 21, 2013 | Bissell Carpet Cleaner Powerbrush Deep...
How much water should I put in Eureka model 300 steamer
Use 12 ounces of water.
It's best not to use extremely hard water in the Eureka steamer due to mineral deposits it may leave behind.
If you need cloths for your Eureka 300 or 310/311/313A see my listings on eBay by searching "eureka steamer."
This is a great floor cleaning machine. I have several for use on large areas of linoleum and sealed hardwood in our home.
Jan 04, 2009 | Euro-Pro Shark SC-505 Handheld Steam...
Bissell carpet cleaner not spraying water out of bladder
my bissell machine was bought 2nd hand and I can see where to put the water in...too complicated...anyone have the bissell proheat pro-tech with scotchgard i believe the model # is 010-5458
May 08, 2008 | Vacuums
Dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Bissell 1960-3 QuickSteamer Plus Upright Vacuum Logo
154 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
