Question about Konaki DV7-Z Digital Camera
Is there an auto-off function?
Does anyone have the manual for the konaki dv7-z?
I'm having a problem with the camera shutting down as soon as I turn it on to take pictures. I can still view everything on my card, but as soon as i turn it to the 'take pictures' mode, it shuts down. I tried emailing konaki but they were of little help other then telling me to check if the auto-off was selected. I can't find that option anywhere,but it makes sense that that is what it is doing. Can anyone tell me how to change the auto-off function so that I can use my camera?
  • lmezzo23 Apr 23, 2008
    I had the same problem, and I came to find out that somehow I filled the entire memory card with a video recording. As soon as I figured that out, and went in and erased the video, the camera was fine. Hope this helps! :)
  • lmezzo23 Nov 11, 2008
    I had the same problem again and this time the lens was stuck. I opened the shutters and blew in the lens a couple of times and when i tured the camera on, it worked. :)
I had this same problem again, and this time the lens was stuck. I opened the shutters and blew in the lens a couple of times, and fiddled around with the lens area. When I turned the camera on, it seemed to work. :)
Posted on Nov 11, 2008
I had the same problem and when I held down the menu button and the on button the problem was fixed. Hope it works for you.
Posted on Mar 18, 2008
Canon powershot elph 320 hs
Hi Doug,
You are right in identifying the cause of the pre-mature shut-down of the camera during video recording. Battery saving features (auto-shut down) detect the camera as idle while you are recording. you could do two things to avoid this;
1. A short term practice is to manipulate the camera to stay on by using the zoom button, taking a snap-shot or anything like that from time-to-time, before the 2 minutes is up. This will keep the camera awake long enough for you to record a good length of video.
2. The second and permanent option is to program the camera - just as you mentioned. You can do that by opening the menu and under camera setting , scroll down till you find the auto-power save. Change the time to your preference
Please note: You have to switch off your camera as soon as practicable while the auto-switch-off time is set at a bigger value to conserve the battery. otherwise the battery will be drained quicker than you imagine.
I hope this helps.
Sep 01, 2014 | Canon Cameras
HP dv7-4165dx keeps shutting down
When does it shut down? Does it boot up and allow you to do anything? If it allows you to do some things then maybe it is running hot and shuts down or a virus is shutting it down. Give us more details on when it shuts down and what was going on when it shut down.
May 02, 2012 | HP Pavilion dv7-1245dx Notebook
Hi... i am just looking for the manual in pdf for the Konaki DV7-Z 2.5. Any help will be very much appreciated. - david
http://content.janome.com/documents/File/ManualFile/inst%20book%20MC3000.pdf
i believe the above link might be helpful....
Jun 23, 2011 | Konaki Cameras
Konaki DV7-z camera says card is locked. How do I get it unlocked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 12, 2010 | Konaki DV7-Z Digital Camera
User Manuel
http://www.7elephants.com/images/MANUALS/DV-5.pdf
this is the one i found for dv5hd hopefully it is the right one
May 25, 2010 | Konaki DV6 Flash Media Camcorder
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
The lens comes out then the camera turns off
Your camera has it own doctor built in, if it sees an internal error it will shut down. When a camera turns on it goes through a series of tests, if one of these test fails your camera records an error. If the lens is moving in and out your camera is trying to get the lens to function. As such you have a faulty camera.
Jul 02, 2009 | Kodak EASYSHARE M1063 Digital Camera
Driver/software
heres the link to their main website , go to DOWNLOAD on top of website , and follow it from there , good luck , AJ
http://www.konaki.com/product.html
May 19, 2008 | Konaki DV6 PLUS Digital Camera
Konaki DV7-Z Digital Camera Logo
66 people viewed this question
Top Konaki Cameras Experts
Are you a Konaki Camera Expert? Answer questions, earn points and help others
