Computer stopped working
My computer screen went blank without warning. now the computer will not boot up. the light only blinks yellow.
  • 2 more comments
  • P123 Feb 23, 2008
    pc light not coming on at all now
  • dtbandunknow Jun 04, 2008
    the computer screen is in powersaving mode and the computer is runnin but nothin on screen i no the pins are good cuz when disconnected the moniter say no signal but when connected is show powersavin mode i just want to what part of the computer is broken is it my video card or wat
  • Anonymous Apr 04, 2009
    i have the yellow ligth 2 is the video card that burned out buy another one if the powersupply fan is still on and the video card is still on is the video card
  • Marty marty May 11, 2010
    the light only blinks yellow.... which one...the pc or monitor? if monitor, then pc power supply died
  • 48 Answers
Try look your cord wire if connected is okay... or change your monitor
Posted on Feb 23, 2008
Will not boot up. blank screen
Can you see any light on your computer? Or hear your computer running? Have you tried turning of the power and turning it back on? Also check if the cables on the back of your monitor are still firmly connected. as well on the computer side.
Listen for the computer if it makes any kind of sounds when you turn it on.
Jan 08, 2015 | Computers & Internet
The screen went blank and camera will not turn off. None of the buttons work
Every time a digital camera acts strange, just remove he battery But not before al lights are out!!! When the camera is accessing the memory card a light will blink. As long as the light is blinking, don't switch off or remove the battery.
Removing the battery and reinserting it, has the same effect as a clod boot of a computer.
After this action any error should be gone. If an error keeps coming back something more serious is going on. Then contact a certified repair centre that services your brand of camera.
Apr 14, 2014 | Nikon COOLPIX S3300
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
E640 REBOOT
Hi John,
I see you mentioned you update IE9 then you now get a blank screen...
If I may ask the blank screen showed up after the update or did it show up after restarting the computer?
If your getting a Blank screen when you boot into windows after the IE9 update, try rebooting then boot into Safemode.
Restart you computer then as soon as you see the Boot screen of you computer keep on Tapping f8 to get a list select safemode, then once it boots into safemode windows will load up in safemode on the issue and you can navigate arround to fix things that went wrong.
click on the Start Button on the lower left of the task bar then, click on Programs, select accessories then select system tools, look for system restore then select the option select a different restore point, on the window you may see a list of restore points hoping your system restore was turned on in the very beginning, once you have selected a restore point keep on clicking next then a warning will show just click next again then it will restart your computer.
System restore allows you to restore to a date where you had windows working fine without any problems so if you can get a restore point before updating IE9 then it is possible that you may be able to fix you windows back the way it was.
I hope that this will help,
michaelvincentc
Dec 22, 2011 | E-Machines W Computers & Internet
My monitor screen is black and the yellow standby light is blinking. I can not get the light to stop blinking or get the monitor to show anything, but a black screen. What can I do to coerrect the problem?
mcdevito75 here, Press the SHIFT key, a screen should come up telling you too click on your user name, left lower side of screen. If this doesn"t work, press the yellow blinking light on the monitor see if picture comes back, then follow the directions. If this doesn"t work, shut computer down with switch on the computer itself. Hope this helps.
Jul 17, 2010 | Acer Computers & Internet
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
Jul 21, 2009 | Computers & Internet
Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
I have PHILIPS 42pfl5332d/37. I was watching tv, and suddenly the screen goes blank. There's a blue light that turns on when the tv's on, however when the screen went blank, that blue light turned orange...
I don't have that problem, my problem is that I lost my remote control, so I can't configure de channels.. I just have 4.. =S.. I can see the menu, but in the part that say start configuration, I cant activated without the control, I don't know what to do.. aNybody Knows??
May 19, 2008 | Televison & Video
Montier is blank when i stat up
Your monitor should have a light on it that indicates if it has signal, if the light stays yellow(or blinks) as the computer boots it is not getting the signal from the pc. Check the VGA cable on the back of your computer, it a big blue connecter, it has to be unscrewed and and disconnect it to verify that none of the pins are bent, plug it back in snugly and see what happens.
Sep 16, 2007 | Computers & Internet
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
