Question about Durabrand PDV-705 Portable DVD Player
Battery My battery has swollen up to twice its size, is this in danger of exploding of catching fire as with some batteries i've heard of??
    Genius:
  • 1,019 Answers
This battery is dangerous.
Please replace it and dispose of it correctly.
It may-explode-crack or leak in it,s condition.
I,d suggest that you dispose of this Now.
Do not use in the laptop-Do not attempt to charge it.
Mike @ Compurepair.
Posted on Feb 23, 2008
Is it true that iPhone 7 battery explodes?
Some of them do and some catch fire. Lithium batteries are very powerful but also very volatile and any exposure to air/oxygen sets them off. That is why it is so important that the container they are in is not compromised physically in any way.
Oct 22, 2016 | Cell Phones
The back popped open on my ematic and the silver pouch inside is swollen How do I fix it
Whilst I am not familiar with the brand of tablet you have, please be warned that it is in a dangerous condition. The "silver pouch" you mention is the Lithium battery that powers the tablet, and the fact that it is swollen means it is faulty and could rupture (split open) anytime. The danger here is that the Lithium inside the battery will ignite in a very hot flame if it comes into contact with air, which it obviously will if the battery splits open. Do not store the tablet inside your home until the battery has been replaced. My advice would be to unplug and remove the battery if it is plugged into the mainboard of the tablet, place it inside a fire resistant container, and take it to your nearest battery disposal location. Then you can most probably source a replacement battery either on eBay or from the store where you purchased the tablet. If the battery is soldered in place and you do not have the tools or expertise to remove it, then I'd advise that you call a local PC or cellphone repair company and see if they are willing to remove and replace the battery for you. If they are, take the tablet to them (in a metal bucket or similar, just in case the battery fails). The swelling of the battery's casing is the result of gasses being generated inside the battery, and indicate that it may be in a very dangerous condition, so I stress again, it is a potential fire hazard and should not be kept it inside a building unless it's in a fire retardant location.
Jan 02, 2015 | Tablets & eReaders
I NEED A Replacement BATTERY. I have a bulge in mines.
Dear Janice,
DANGER! DO NOT USE THE DEVICE! DISCONNECT FROM MAINS POWER SUPPLY! FAULTY BATTERIES CAN EXPLODE/CATCH FIRE! PLEASE CONTACT YOUR SUPPLIER IN THE FIRST INSTANCE; If that fails to satisfactorilly solve your problem - then contact the manufacturer...ask re local agent for repair. GBU!
Dec 27, 2014 | Durabrand Televison & Video
Snopes truth fiction
As mythbusters would say : Plausible.
Garmin's use Lithium Ion battery technology which can explode and catch fire. Garmin issued an older series of devices a Battery Recall because of some reported instances call their support number and they can tell you if your Garmin serial number has been recalled. Understand though that it is a battery issue and many companies have dealt with exploding batteries. Try reading this for more info.
Why lithium batteries keep catching fire
Jul 19, 2014 | Garmin GPS
My zte majesty battery heats up n charge doesn't hold, do I need a battery or is it the phone?
I myself would replace that battery, yes. If it gets too over-heated, there is a possibility it could explode or catch fire. At the least over-heating can ruin your phone itself.
Apr 24, 2014 | ZTE Cell Phones
Rc helicopter battery
Tip #1: Wait at least 15-20 minutes after you drain a battery to charge it.
This allows the battery to cool down before each charge cycle. I would make sure the battery is cool to the touch before charging it again, but 15 minutes should be alright.
Pointer #1: If the battery is hot after use, then it is a good sign that your battery is getting old.
Anything warmer than about 140 degrees is dangerous; if your battery is this warm after flying, it's time to replace it. I wouldn't use it anymore so it doesn't explode. This is a good indication that in the near future you should look to getting a new one. I would recommend a higher quality / mAh battery (keep the same voltage, though) if the battery running out is a stock battery.
Tip # 2: Wait at least 15 minutes after charging a battery to use it.
Once again, this is to let the battery's chemical processes have a break.
Pointer #2: Battery terms to understand when buying a RC battery.
mAh: Milli Ampere Hour. This is basically the electric charge transferred by a current of one milliampere for one hour. I'm no electrical genius, but the higher the mAh, the longer a battery will last per charge. This is the one part of a battery that you can change without damaging the heli.
Volt: The electrical pressure. Basically this determines how much power can flow to the motor. For lipo batteries the voltage comes in multiples of 3.7 volts, or 3.7 volts per cell.
Cell: An independent 3.7 volt battery.
If you would like a little more in-depth explanation, I found this howstuffworks article helpful.
Litium-Ion (Li-Ion): a type of battery that has a rigid cell structure and shape. It is safer than a lipo battery, but not as efficient.
Lithium-Polymer (Lipo): a type of battery with a flexible cell structure and shape. Lipos can catch fire and explode if mistreated or dropped on a hard surface. BE CAREFUL! Although more dangerous, they are more efficient than li-ion batteries and can come in practically any shape with the same cell count.
Look below to see how the li-ion (on the right) has two defined cylindrical shapes in the package, whereas the lipo to the left is just a rectangle with no visible curvature or cells.
Jul 19, 2013 | Cell Phones
Battery on my advent 5311 has blown
Hi.
First of all take out the battery !!!! The battery is failing, it could explode and cause untold damage to the laptop and could possibly catch fire.
Use the laptop on AC power only and DO NOT use the battery at all until you have a replacement battery for the laptop.
Regards.
Dec 08, 2011 | Computers & Internet
When i am charge the camera and after trying to open it saying battery temperature high problem
You have a bad battery or the battery controller inside the battery is out. What happens is the battery overcharges and the battery produces more power than it should. It also can get into a problem where it keeps getting hotter and hotter until it catches fire. Doesn't happen that often in camera battery's but is a lot more common in other lithium type batteries. Anyway this isn't something you want to ignore. Just go replace the battery with a new one and toss out the hot one. Don't try to use it just in case it decides to thermally run away and catch fire or explode one day.
You can find new replacement batteries online much cheaper than buying from the manufacturer or their dealers. Just do a search for your camera type and battery ie "Canon rebel battery" and then find someone close or cheap or both. You can save yourself a lot of money if the shipping is cheap. I purchased a battery for $15 instead of $70. Works fine and at that price can buy a few more if needed.
This isn't dangerous now but it can be so you do need to replace this battery. Take it out of the camera and don't use it and you will be fine.
Feb 04, 2011 | Cameras
Razor e300 batteries are bulging. Is that normal?
Bulging battery means u have to replace it, the plates started to oxidize and pushes the everything out!
Nov 09, 2010 | Razor E300 Scooter
Acer laptop Aspire Model the battery turns hot.
Laptop batteries do get warm when they are in use or charging but not so hot to cook eggs.
This is dangerous and it could explode and catch fire.There could be a problem with the charging circutry or a faulty battery. Get it checked out.
Nov 18, 2008 | Acer Aspire 4315 Notebook
Durabrand PDV-705 Portable DVD Player Logo
65 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
