Question about GE Spacemaker JVM1640SJ Microwave Oven
GE xl1800 spacesaver microwave
Grinding noise when we cook bacon (could be with other things too, but just noticed w/bacon 2 times). it sounds like it is shaking the unit like it will pop. it began after our son put a chili microwavable bowl w/out removing the metal top into the microwave.
  • Anonymous Mar 26, 2014
    I need a cooking chart for the Bacon Wave. Thank you.
It sounds like you could have one or two problems. Using the oven with metal in it could cause the magnatron to go bad at its tip causing it to arc and making a popping sound. It could be that there is bare metal exposed somewhere causing the popping sound. Take it in for service!!
Posted on Feb 24, 2008
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
I have a GE Spacemaker XL1800, about six years old. It heats food fine, but there is a terrible grinding sound while it does so, for the entire time it is running. This has been going on for several...
Personally, I would replace the Microwave. It is bound to be below specification by now if it has been used quite a bit.
Then you will know you will be fine for a few years.
Dec 15, 2010 | GE XL1800 1100 Watts Microwave Oven
GE spacesaver xl1800 microwave. Unit comes on, but no heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
agf
Jun 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave makes a strange humming noise when it is running. It does not do it all the time, sometime it starts part way through the cooking process. I would appreciate some advice as I am worried...
This could be a laminate plate in a transformer or the magnetron. It is nothing to worry about. If it fails there wont be any excessive damage. The cost to eliminate a noise is not worth it and this problem will not cause any other things to go wrong.
Oct 14, 2017 | GE Microwave Ovens
Ge JVM1190 appears to be working but does not cook.
I spoke with a qualified microwave technician who advised me to buy a new microwave as the problem I was having indicated that the magnetron tube had blown. What a waste of time to ask for help from you.
Sep 01, 2008 | GE JVM1190 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
262 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
