Question about EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard
Just built a comp using this mobo and when i switch it on, it beeps continuously
now i have two different ddr2 ram sticks and have tried them in all the different combinations but nothing happens still
Is it the mobo which is broken?
I have the same problem though i put my mobo in a atx case not mirco atx i think that is the problem is yours in a atx case to if so u need to get a mirco atx case because of the front connectors
Posted on Mar 22, 2008
    Brigadier General:
  • 3,614 Answers
Did you use the on board video? Try to repalced the video card.
Posted on Feb 23, 2008
I have put a "GB DDR2 -800 in each memory slot in
because there is a defect with the dimm slot 2 on these mobos.I have the same problem.contact ecs therell give you a bios update but it wont work
Nov 09, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
Can I use Kingston 1GB PC2-5300 667MHz DDR2
I would assume that specific module would work, although it is not found on the QVL list from ECS for 1GB.. Most Kingston memory is pretty good with compatibility... However, in some cases, some motherboards will have trouble with the type of RAM you put into it. I would try to follow the spec from ECS listed HERE.
In the worst case, most retail stores will allow you to return the module and exchange it for another one if it does not work in your system.
Hope this helps!
Thanks for using FixYa!
Jun 30, 2010 | EliteGroup ECS GeForce6100SM-M (1.0)...
Computer beeps, won't start up
Nope not a motherboard problem, a RAM problem, the constant beeps give it away...you may have damaged one of the sticks..try with one stick, then the other and see if it works...
Apr 20, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
ECS 915-A(1.1) Ram Reading Issues
Is it a single ram module or dual ie. 2x 1gig ddr2 533?
What motherboard are you running?
Is it possible that you've given a static charge out while handling the ram?
Feb 27, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
No Audio on ECS 6100SM-M2 mobo d
Go to the Startup Bios Configuration Utility By Presing Specific hotkey. Probanly you having Audio Device as Following
Realtek ALC660/ALC662 6-channel audio Enable or Reinstall Driver As link given here >>> http://www.esoft.web.id/go/WDM_R210.exe
Hope you will have good result
Regards
Feb 01, 2009 | EliteGroup ECS GeForce6100SM-M (1.0)...
EliteGroup ECS GeForce6100SM-M video problems
You are the fourth person I have helped with this board. One would think that ECS would have this posted on their site. Please update you're bios. Click on this link: http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=685&DetailName=Bios&MenuID=1&LanID=9
Two user's tried 2 different settings & each worked out fine. You made the correct setting in you're bios. After flashing the bios to the latest bios file. Re-check you're settings. You may find you're setting will function. If not you will have to change the bios setting to Enable. According to ECS the bios will automatically turn off the onboard video. As I mentioned, this does & does not work. Try both settings if Disable fails to load with out the blue screen.
Good Luck!
m
Jun 07, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Atx12v1 cable
The repeating single beep with a small pause (actually 3 Beeps a Pause) clearly indicates problems with RAM .Replace it ,your problem will be solved . As for connecting the 12 volt 4 pin connector all mobos are designed to sense the presence of this 12 volts and ONLY THEN TURN ON.
May 02, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
EliteGroup ECS GeForce6100SM-M (1.0) Socket AM2/ MCP61S/ SATA2/ A&V&L/ MATX Motherboard Logo
130 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
