Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsu-wd-52527 lamp replacement
Is it difficult to replace the lamp in this tv. could I do it?
  • 927 Answers
The lamp in this TV is very easy to change. I recommend to use your owners manual, but the front cover snaps off, using screw driver open lamp door, unscrew lamp, pull out with handle, make sure lamp is cool. Replace, follow onscreen display to reset lamp hours. Use remote to enter information.
Posted on Feb 23, 2008
I have a 2005 52 inch Mitsu turn it on and it goes to red light
di you replace the power for the lamp in your manul it will show you the lite set for your tv it it will give you i ideal what wrong. i see so with bad power supply or
the balstor go bad to i chang lamp bastor frist. when
the lamp go bad it will show you it the lamp in front of dlp. i hope this help you out.
Dec 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lamp light is red
pull lamp from unit and investigate it for integrity
Jul 07, 2009 | Mitsubishi WD52527 52" Projection HDTV
Tv color not bright enough and just replaced lamp
Clean the small mirror in front that projects the image onto the rear mirror. The Rear mirror always stays good but the front small mirror gets dusty and the colors and bright levels get affected and appear dim.
Jun 09, 2009 | Mitsubishi WD52527 52" Projection HDTV
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Burnt out lamps
There is only one lamp need. If you keep your user's manual refer to ...how to replace the lamp. (I recommend to use an original mitsubishi lamp) process is kind or smooth path to the user, But if you are not feeling comfortable replacing it a serviceman can give you an estimate on it.
Apr 22, 2009 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
141 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
