Question about Philips WACS700 Shelf System
Wacs700 i have gone through the whole process of connecting to my pc and all info is on both centre and station but now station will not connect to centre - need help asap
  • 476 Answers
From HDD mode on the centre, press menu and select "Station Management".
If the option is available select "Delete Station" and delete any stations listed.
Select "Add New Station" and the unit will start searching.
On the station press menu and select "installation mode"
If this option is not available, try from another source setting, such as AUX.
Once the centre has found the station, press stop on the centre, as the station cannot connect until the centre has stopped searching.
If this doesn't work, you will have to reset both units to factory settings and start again.(Menu -----> Settings ------> Restore)
Posted on Mar 03, 2008
Wireless installer will not run on windows 7 were can i get upto date version
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?tmplt=Connected%20Planet&scy=US&slg=AEN&sct=WIRELESS_MUSIC_SYSTEMS_SU&cat=WIRELESS_AUDIO_PROD_CA&session=20101231125310_98.239.101.159&grp=SOUND_AND_VISION_GR&ctn=WACS700/37B&mid=Link_Software&hlt=Link_Software
Theres updating the Firmware(which updates the product through PC)
Also Windows 7 doesnt have the back-up feature for a product in 2005
I have link to update firmware here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpcontent.pl?tmplt=Connected Planet&scy=US&slg=AEN&mid=Link_Software&cat=WIRELESS_AUDIO_PROD_CA&sct=WIRELESS_MUSIC_SYSTEMS_SU&grp=SOUND_AND_VISION_GR&session=20101231125310_98.239.101.159&ctn=WACS700/37B&dct=FUS&did=AEN&reldct=FUR&file=/files/w/wacs700_37b/wacs700_37b_fur_eng.pdf#toolbar=0&zoom=100
Dec 31, 2010 | Philips WACS700 Shelf System
My WACS 700 System seems to have trouble maintaining the connection between the Centre and the station
I moved my station to another position in the house and it worked  --I think originally there were too many walls between the Centre and the station
Feb 21, 2010 | Philips WACS700 Shelf System
Wacs700 connection to my pc via wireless
use http://www.lucia-mathias.com/wacs/, it will find music center as long as security settings for wireless are correct, if never connected to a pc use the original pilips disc to set up first
Aug 13, 2008 | Philips WACS700 Shelf System
WACS700 NOT CONNECTING TO STATION
Mine did the same, the station was trying to connect on channel 1 wi-fi where the centre was on channel 11, check under information and wi-fi for both. I then did a restore on the station, put both into installation mode and they found each other after a few mins.
Hope this helps
Jul 08, 2008 | Philips WACS700 Shelf System
Tracks skipping on centre
Sounds like you have ripped the files at too high a rate - max 192kps on the stations
Jul 03, 2008 | Philips WACS700 Shelf System
Wireless connection
Go to the Setitings menu on the Centre and all Stations. Select restore.
They will all revert to factory settings, so you can install them again.
When the centre has found all the stations, press stop on the centre, as they cannot connect until the centre has stopped searching.
Feb 21, 2008 | Philips WACS700 Shelf System
Station wont register
Make sure the station is put into "Installation Mode" (Menu ----> Installation mode) when you try to add station.
If this doesn't work, you probably have a faulty station.
Jan 05, 2008 | Philips WACS700 Shelf System
Creating playlist using DMM
sounds like you are switching off before mc has finished save, best software for transfwr etc can be found at http://www.lucia-mathias.com/wacs/, this is much easier than dmm and can upload tracks back to pc.
Dec 02, 2007 | Philips WACS700 Shelf System
Wacs 700 will not connect to computer and keeps saying music centre could not be found
If you have set up the station to receive signals exactly as the manual instructs, try establishing the connection in a different room. I found that the original room that I tried to set the station up in had too much interference. Loaded fine in the kitchen.
Nov 25, 2007 | Philips WACS700 Shelf System
Wacs700
Don't use the remote control. Use the buttons on the unit. You should be able to get into Station Management then.
Nov 11, 2007 | Philips WACS700 Shelf System
Philips WACS700 Shelf System Logo
340 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
